ideas for louder system
i was running my fronts and rears off a phoneix gold 4 channel amp.
but becoz my headunit only has 2 sets of rcas, i need to split the rear rcas for the sub.
so wen i did this, my rear speakers are not as loud. so is it because of splitting the rear rcas they have gone softer becoz of some power issue?
so for me to get better sound, should i use a 2 channel amp for the fronts and another 2 channel for the rears?
which means 3 amps in d boot
and to that, can i mount 2 ground cables at one point? at the moment i have to seperate grounding points but if i was to have another amp i dont want to look for a third.
another thing, should i use splits for rear speakers or just some 3 ways?
i want it loud without using 6x9's.
oh also, my front and rears are on HPF so there is no bass, i use the sub for bass only. is that the correct way? or should i use Full pass for the rears..
thanks in advance.
