Results 11 to 20 of 25
Thread: ideas for louder system
    Nov 2005
    Sydney NSW
    Read you manual again about hooking up speakers.
    There is a metod that some amps can cope with, that you wire up the sub directly to the rear speakers like so
    RL- = Speaker and Sub
    RL+ = Speaker
    RR- = Speaker
    RR+ = Spearker and Sub
    This method does crank! and means you do not use another amp - but the amp has to be able to handle add a Sub like this.
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
    Aug 2006
    thats a crap method.. so ur running 2 s ets of speakers and a sub off 1 amp
    Mar 2007
    sydney
    Quote Originally Posted by 1DUB2C View Post
    just buy a good head unit with 4-5 pre outs front,rear,sub,aux1,aux2
    and a 5 channel amp if you dont to have amps everywere
    Aug 2006
    yeh i might end up getting new head unit, but for now i would like to get my aux out working.. might take it to professionals to get it checkd out.
    Aug 2005
    Prahran, Vic
    if you plug rcas into the aux out on your amp, it should work. it should be that easy. maybe its come loose inside the amp or something. take it to fhrx, see if one of them can get it working.
    Feb 2007
    Bunyip, Victoria
    I use this method for my center channel.
    Ive also used it to run a 15" sub + speakers.
    you need to get a low pass filter though.
    Aug 2006
    omg i got he aux working!! it was a dodgy rca i had.
    but now, wen i start the car and headunit turns on, the sub makes a big bass note then goes to normal. whats the go?
    Aug 2006
    Skye, Victoria
    you need a turn on delay on your sub amp, about 10-15 seconds should do the trick.
    Aug 2006
    Quote Originally Posted by BlackVr6ix View Post
    please explain? how do i turn on delay? dont see any buttons or anything like dat...
    Aug 2006
    Skye, Victoria
    you need to either purchase or build one. search for turn on delay on google or similar.
