Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: ideas for louder system
    Aug 2006
    i was running my fronts and rears off a phoneix gold 4 channel amp.
    but becoz my headunit only has 2 sets of rcas, i need to split the rear rcas for the sub.
    so wen i did this, my rear speakers are not as loud. so is it because of splitting the rear rcas they have gone softer becoz of some power issue?
    so for me to get better sound, should i use a 2 channel amp for the fronts and another 2 channel for the rears?
    which means 3 amps in d boot
    and to that, can i mount 2 ground cables at one point? at the moment i have to seperate grounding points but if i was to have another amp i dont want to look for a third.
    another thing, should i use splits for rear speakers or just some 3 ways?
    i want it loud without using 6x9's.
    oh also, my front and rears are on HPF so there is no bass, i use the sub for bass only. is that the correct way? or should i use Full pass for the rears..
    thanks in advance.
    Feb 2007
    Bunyip, Victoria
    the reason you have expearianced a loss, is because you have split the voltage to each set of channels. to recitifie this you would need a full set of outputs. also put all the speakers on a high pass and use the sub to make bass.
    Use a good co-ax in the rears, splits are over kill in the rear.
    i dont use rears at all.
    Can i have your amp? Phenix gold rocks.
    Aug 2006
    haha
    you can buy it or we can trade
    so what way do you suggest for me to hook up the sub which out using splitters.
    also, co-ax is that like 2way, 3way speakers?
    i want it loudest as possible thats why i wanted splits..
    edit:: i forgot to add, my phoneix gold amp has a AUX out. i thought this was to run another set of rca to another amp, but it does NOT work.
    Aug 2006
    picture of the amp added showing AUX.
    Feb 2007
    Bunyip, Victoria
    Quote Originally Posted by 1DUB2C View Post
    haha
    If you want go get loud, get powerful. That amp is heaps powerfull, what you need is control over it. Get a headunit with 3 set of preouts, so that you get full voltages to all the imputs. Try some high end Co-ax (2 or 3 way) speakers for the rear. Splits are mainly for front use.
    Aug 2006
    hmm..
    as you told me b4, change the input to front only. if i did this, wouldnt it mean my sub wont work because it uses rears?
    as for a new h/u i dont really want to spend my money on one, any other ways? i'd like to know what the aux is for and how to use it.
    Aug 2006
    Skye, Victoria
    there will be a way to enable the aux out. try looking in the manual. if you can get the pass through working you wont get any signal drop.
    Aug 2006
    i have loked thru the manual 100 times jst incase i missed it..
    does not tell me how to use it, only say it has aux lol
    also no bottons to turn or anything..
    am i supposed to use a special cable??
    i'v only tried with rca
    Feb 2007
    Perth, WA
    Hmm, run your rears off the HU's amp?? Rear's are only good as fill in for humans stuffed into the back. They do not matter as much as the driver
    Aug 2006
    i dont cruise alone
    needs to be loud all round haha
