thats a crap method.. so ur running 2 s ets of speakers and a sub off 1 amp
Read you manual again about hooking up speakers.
There is a metod that some amps can cope with, that you wire up the sub directly to the rear speakers like so
RL- = Speaker and Sub
RL+ = Speaker
RR- = Speaker
RR+ = Spearker and Sub
This method does crank! and means you do not use another amp - but the amp has to be able to handle add a Sub like this.
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
yeh i might end up getting new head unit, but for now i would like to get my aux out working.. might take it to professionals to get it checkd out.
if you plug rcas into the aux out on your amp, it should work. it should be that easy. maybe its come loose inside the amp or something. take it to fhrx, see if one of them can get it working.
omg i got he aux working!! it was a dodgy rca i had.
but now, wen i start the car and headunit turns on, the sub makes a big bass note then goes to normal. whats the go?
you need a turn on delay on your sub amp, about 10-15 seconds should do the trick.
you need to either purchase or build one. search for turn on delay on google or similar.
