Hey mate, you've got half your car in parts already!
I've had some good audio setups for normal people like us using Jaycar stuff in my past.
In my opinion, leave the rears stock, from the headunit. You only hear "fill" from the rear pretty much anyhow.
Spend the time and money on the fronts. Again, I can't advise highly enough replacing JUST the fronts with a decent set of splits, and putting a little dynamat bitumen sheet under each one. Use the stock wires, and just buy a jaycar 2 channel amp to suit the fronts. You don't need huge power to get half decent sound. The audiophiles will disagree, but spend the cash and research on speakers. THEY make the sound.
I have a decent Stinger LOC II and gold / shielded RCA input and output wiring to suit, all in great nick, which you can have. It was from the audio setup I had planned for the Ford, and of no use to me anymore. Will let you swap 2 channel line in to 4 channels out. Yeah yeah you audio types, it won't be SQ quality.... but a wack better than stock!
So you need an amp, some splits and I am happy to give you two woofer suitable squares of dynamat, as I have p-l-e-n-t-y. This will give you a heap of bang for buck, and in my opinion a fine sound. If you do buy that 4 channel amp, you can easily add a sub later on for more punch, and Jaycar have a fabulous 10" for the money ($150). I recently put one of these in a Lancer I fixed up for a quick sale, and it sounded awesome for the cash. Basically sold the car actually!
Easy come in a lot less than a grand.
