Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: How to re-partition the HDD in your RNS510
    ************BIG DISLAIMER ************
    As with all such operations, the user accepts all responsibility for any issues which may be caused by modifying their RNS510 navigation system.
    ***********End disclaimer**************
    UPDATE
    Now also working with 39xx series firmware. See this thread.
    Have an RNS510 and annoyed by how much space is wasted to the map partition?
    (The default settings assign 67% of available space for music and 33% for the mapping data regardless of drive size.)
    Have you upgraded the OEM hard drive with a larger SSD using JOhnC's excellent guide http://www.vwwatercooled.org.au/foru...diy-60984.html and even MORE annoyed by how much space is being wasted for the map partition?
    Then look no further.
    Thanks to vwnavi user josi I present a guide for changing the partition scheme using 276x firmware.
    Before you proceed, please read this first section VERY carefully:
    You will lose all your music and your map data! You have been warned!
    Required for the operation:
    1. 276x firmware CD. Carefully read the warnings to make sure that your setup is compatible with this version:
    Volkswagen RNS 510 Firmware Upgrade to version 2760 / 2762 / 2764 / 2766 / 2768 | my-gti.com
    Note for Skoda Columbus owners the test menu is not enabled in this firmware image by default, you need to edit a file before burning the disk according to these instructions:
    Accessing the Setup Menu on RNS 510 head units with firmware version 2660 / 2662 / 2664 / 2666 / 2668 | my-gti.com
    2. Map DVD
    3. Custom files which specify the new partition ratios to make yourself a new copy of the 276x firmware disk with new partition ratios.
    MEGAUPLOAD - The leading online storage and file delivery service
    4. SWL recovery CD (make a copy if this and have it handy in case it is required) from
    Unofficial 272x software and SWL recovery CD
    Instructions
    A. Create the custom firmware CD. Extract the files from the 276x ISO to your PC. You need to replace 2 files. Use the ones downloaded above in step 3.
    You need to replace the existing files with those you downloaded ie delete the originals and rename the ones you downloaded to the correct filename.
    The first one is ecuorder.txt.
    This file MUST be EXACTLY 414 bytes.
    Second file is HDD\HDD_20GB\RNSMIDEC\CONFIG\DlScript.txt
    There are two options here. The first is for those with 30GB or 40GB HDDs, and gives you 90% of available space for music. Use DlScript_90.txt
    This file MUST be EXACTLY 1821 bytes
    Optionally for those with 40GB or larger HDDs, gives 95% to music, use DlScript_95.txt
    This file MUST be EXACTLY 1820 bytes
    Burn the new CD as an ISO9660.
    B. If you are running another firmware version than 276x you will first need to load the standard 276x version. If you are above this version you first need to enable firmware downgrade. Refer to the guide on how to enable test menu in step 1 above.
    C. Once you are running 276x firmware, enable software downgrade from the test menu (hold down setup button for about 10 seconds until the 'secret' test menu appears. Go down to system, then enable firmware downgrade. Do not put the keys into the ignition, just insert the CD.
    D. Insert your new 'custom partitions' CD. Follow the prompts and let the firmware load. System will reboot a few times.
    Once it ejects the CD and restarts into normal mode, you will need to reload your map data. Insert the navigation DVD.
    The maps will start loading automatically, takes about 15 mins. If you hit the eject button before they are copied, you will get a warning.
    E. Copy some music to the HDD and enjoy the newfound space!
    Note: you cannot edit the files to change the ratios as it will change the checksum of the file and the firmware CD will be rejected as not a valid SWL source.
    Please let me know if there is anything that is not clear here, this is a first draft. Suggestions for improvements welcome!
    Jun 2009
    Western Sydney
    Kamold, you sir have done it.
    I followed the steps exactly as listed and it worked a treat.
    Brilliant work! You've reclaimed the dead space I was missing after having gone to the version 3 beta. It's nice to be back on version 2 with the added bonus. If only we got to keep the nice new load screen.
    Big thanks to you and josi for figuring it out. I'll see if the guys want this applied to their SSD units I did for them.
    I'll make sure I link to this thread in my SSD swap thread.
    No real suggestions for improvements. It was all really clear to me.
    Glad I could return the favour for your HDD upgrade guide
    As for the system start screen, stay tuned....the capability to insert a custom image file into the appropriate fragment file and save it to the internal NOR flash does exist...
    Feb 2009
    Sydney, Australia
    A big thanks to johnc and kamold for this. I know that all the hard work in this thread was by kamold, but johnc did the hardwork in the companion thread.
    Great work guys
    Jun 2009
    Western Sydney
    This is all kamold's work right here. I don't deserve any cred for this baby.
    Apr 2008
    We have another happy customer!
    Dead easy to do and good write up.
    You've definitely earned your place in the forum hall of fame kamold.
    Jul 2005
    Newcastle, NSW
    Quote Originally Posted by johnc View Post
    Well I can give you some cred if I come past and you repartition mine?
    Apr 2008
    I can give you a link to two ISO's to burn if you like...
    Happy to do it for you if you aren't comfortable with the nerd stuff. Usual bribes accepted.
    Aug 2011
    vic
    Is there anyway you can modify the files to enable this on the 3980 firmware? It has 3 partitions, Maps, POIs and Storage, so i only get like 13b spare out of 40
    Also the reason i ask this is that my unit is version D, therefore cant use the 2760 firmware.
