Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: How to Make a Bora slower..
    Feb 2007
    Central Coast, NSW
    Answer is to add more weight. What better way to do it than to add a stereo The car in question is a 01 MKIV Bora 4motion. I would like to thank FHRX for doing the earthing kit and sub box, another awesome job.
    Source for the car is a Pioneer 8650mp, 6.5v pre outs, T/A, 11 band EQ some of its better features. I have also added an Ipod adapter so that the Ipod can live in the glove box away from eyes and be controlled from the front.
    From the engine bay the standard battery, although quite good, had to go. I had an Optima D34 left over from my old car so straight in it went. Then of course the terminals where around the wrong way so that had to be changed as well. Just for fun I decided to add an 300A earthing kit to the engine bay as well just for good measure. Battery has since been replaced with D34m blue top as it has a second set of terminals so I can crank it all day and if I need to jump start I wont damage my gold terminals. Plus its easy to hook up the old battery if I am out somewhere at a show etc.
    Bora has gone ;( Custom sub box and beige floor mats to suit for sale.
    Feb 2007
    Central Coast, NSW
    Then we move onto the front stage. After mush thought I decided to stick with un upgraded version of the existing Boston splits that I had. The SL-60's fitted the bill excellently. With separate dockable xovers it also meant that future expansion would be made easy as they will take bi amp and bi wire and have axis and atenuation control.
    A custom 12mm MDF spacer was used for good mesure for the mids and the last pic shows where the tweeter was mounted on the drives side, high in the kick panel. Height is no problem as the stock grills up the top constantly fool people into thinking the tweeters are behind the factory grill. 2 sheets of Dynamat per door and a dynazorb pad behind each mid.
    Feb 2007
    Central Coast, NSW
    Rears in this case are totally stock. They are faded out so I can not hear them anyways and HP @ 200Hz 12db/oct
    Now I have 2 Audison amp with one being over 40cm long. The other is tiny. The first SRx2 powers the front stage, it produces 2x 65WRMS for the Bostons and the larger SRx2s power the sub with 1x 600WRMS. I really had no choice if I wanted a stockish looking car but to mount them on the rear of the sub box.
    The sub box is a gem made by FHRX. It has 1.1cuft sealed internal capacity and features a 36mm MDF backing, 2x25mm MDF sides, 25mm Perspex across the front, 2 red leds, mirrors and dec board. The first lot of picces are with the older Boston G5 124 that I had and the last ones are with the new OZ Me 12.2 that I have. The install was designed to be as stealthy as possible with the hidden boot and engine bay being the only stand outs. Dec board is currently in the process of being re-done.I hope people can get some idea's from this
    Feb 2008
    New Zealand
    Cool Stuff man!
    Whats with the Foam balls in the sub enclosure tho..
    what is this dyna sorb pad behind the mid..
    and why arent your photos hosted offsite so you can display them loud and proud
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
    Aug 2007
    Horningsea Park
    nice hook up, makes me wanna post up pics of my boras sound system lolz
    Luke
    Aircooled & Watercooled Nut
    62 and a Half Bug
    02 Bora V5
    Feb 2007
    Perth, WA
    An excellent install. FHRX is one of the premier audio guys in OZ!
    I really wish there was an equivalent guy over here in WA. I've had my stereo at 3 different stores and none of them can make it sound good
    Feb 2007
    Central Coast, NSW
    Quote Originally Posted by HitmanR32 View Post
    Cool Stuff man!
    foam balls was an idea, sealed box and they bounce around. It was to hard though to keep enough in so it doesnt work as well as I hoped and I couldn't be bothered to take them out lol.
    Dynazorb is an absorbant pad that you mount behind a speaker to absorb the rear waves. The theory is that is will help elimate the rear waves interfearing with the next cycle from the front hence reducing cancellation and making you speaker louder. They cost about $40 a pair. Focal Chant are better by they are $100
    I have some picces on facebook lol
    Feb 2008
    Auckland NZ
    yeah nice bit of gear, i just cannot quite figure out the location of the tweeters, or least the one tweeter that is, i could not find the other tweeter.
    Does that location give you very good imaging?
    Also does it create the rainbow effect all?
    Just really interested.
    Audi S4 (2001) - Imola Yellow
    Secret Project
    thats some awesome gear you have there Mr ©harisma.
    Firstly, I always LOVe the bora. Secondly GO the BOSTONS !!
    One question, for the speaker on the door, do you have seal the speaker inorder to make use of the Dynazorb ?
    Feb 2008
    Auckland NZ
    Quote Originally Posted by Soundofav6 View Post
    door does not have to be sealed for dynazorb to work.
    Secret Project
