Step seven: Screw the midbass baffle onto the door and seal it with gap filler against the sound deadening. Now you’ll need to use quite larger threaded screws as the factory midbass speakers are riveted in (meaning the mounting holes left over are 4mm). Make sure you also install a gasket between the midbass driver and the spacers because air leaks out here (ever tried to run your car without a head gasket)?
Step eight: Screw the midrange baffles onto the door skin and seal them with foam against the plastic. Again make sure you install a gasket between the midrange driver and the spacers because air will leak through.
Step nine: When it comes to the tweeters we employ a silastic sealant to hold it in place. We do this to save damaging the factory tweeter cover. Remember the tweeter doesn’t actually vibrate that much so this is fastening method is more than acceptable. We also attach some foam to the rear of the tweeter and this is sandwiched between it and the door resisting vibration when in operation.
Step ten: Solder all the trimmed speaker wires onto the various speakers. Don't use crimp terminals because their two best traits are falling off and creating resistance.
Step eleven: Heat shrink around the terminals to protect them. Unlike electrical tape, heat shrink will not begin moving after a couple of months.
Step twelve: Sit back and enjoy your new found midbass. This is what the door looks like when complete:
So there you have it; Golf doors with components installed. Using this method you have about 80mm of mounting depth on the midbass and 40mm depth on the midrange (using varying thicknesses of baffle). If you go any deeper than that your speaker might impact the door trim during large excursions or the window at the rear end.
