Results 1 to 9 of 9
Thread: How do I remove this head unit?
    Nov 2010
    Want to pop out my he'd unit to figure out if its a power drain but will also need to change the USB lead for a new iPhone 5, so how do I get it out? Pics below
    Ta
    2016 MY17 Polo GTI with DA package. TMD fitted + Weather strip and Snow Screen removed otherwise dead standard.
    Pacific Paradise QLD
    I would say you pull the brass colored bits either towards the centre or outwards if that doesnt work and it will slide out
    Depends whether the clips go into the unit or the fitting panel around it Will be one way or the other
    Try sliding a knife blade down one side at a time inside and then outside of the clips and see if that works
    Otherwise you may need some remover tools
    Mar 2009
    UMG Brisbane
    What he said, usually there is a release tab about 5cm from the face and a couple of metal release tools that come with the HU
    If the tabs need to go down the side a bamboo kebab skewer or length of coathanger down the sides. PM me if you are still stuck.
    Al..
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
    Quote Originally Posted by 99_FGT View Post
    Al..
    By the look of that unit it needs flat removers The pin remove units are usually built in models and have two holes on each side.
    Just took one out of a Mazda like that and it didnt look like this one Would say definitely those brass colored bits are the bits to move to get it out That is a unit that has a frame around it that is kept in with tabs behind the dash and usually the clips are screwed into the unit and the tabs lock into the outside frame so pushing them in against the head unit allows it to slide out
    Its definitely not an original fitting
    Nov 2010
    hmmm ok thanks guys.
    Al, might have to give you a message, cheers dude
    Slide a thin knife blad down between the unit and the brass tabs and twist slightly If you live on the northside PM me I live near Bribie island
    Dec 2006
    Kilsyth, VIC
    Looks like it needs the "standard" flat keys.
    I've had luck in the past going to my local autobahn (although to be fair I did to there a lot) and just asked to borrow theirs to rip a stereo out.
    Might be worth a shot.
    If you were local I'd offer my keys, I have a few Pioneer and at least one JVC set here somewhere.
    Mar 2009
    UMG Brisbane
    Yeah - think I have some keys, or can figure something out. PM'd you.
    Al..
    Nov 2010
    cool thanks guys, will be in contact
