Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Help - RNS510 install backfired
    Apr 2009
    Northern Tasmania
    They're commercial CD's & DVD's.
    Battery might be on the way out. $293 for a battery from Skoda. $159, 179, 196 for a cheapo, Alco or Century.
    http://www.everybattery.com.au/skoda_auto_batteries.php
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
    Adelaide hills, SA
    I would go with the BOSCH battery at the moment, however $293 for the battery from Skoda is not that bad, as long as it is VARTA, just make sure it's a fresh battery (not being on the shelf for a year or two).
    Apr 2009
    Northern Tasmania
    Be interesting to see how much the Bosch one is (I would think similar to the Skoda one).
    Messed about with the coding a bit more. Have sound now. I think the no audio was because I had microphone monitoring on, but I changed a couple of things so I'll have to switch them one by one to work out exactly which was the cause. I updated the firmware, but that wasn't the issue.
    Quote Originally Posted by fillmore View Post
    Off topic, but recently had a similar experience. Just received new vcds cable and playing around with it unknowingly put it into transport mode. After auto scan had no interior lights, no radio, and no working key fob. Every scan I did threw up new errors. Thankfully, an email to Ross Tech soon had me sorted.
    This ^^^^^^^^^^^^^^^^^^^^^ is exactly why it's worth every cent to buy a real VCDS cable.
    Adelaide hills, SA
    Quote Originally Posted by wfdTamar View Post
    If you were closer, I would get you Bosch for $200
    Jul 2012
    Bendigo, Victoria
    And it's worth noting that if you buy one second hand, it will cost another $99 to obtain this service.
    MY 09 JETTA 118 TSI 7 spd DSG
    Apr 2009
    Northern Tasmania
    Just an update on this. Went to the local Bosch battery dealer thinking they had a way to test a battery better than I can. Merely tested the voltage (which tells you bugger all). Completely unhelpful - I think they expected me to buy a battery on a hunch. Grouchy as hell too - the usual thing you get at these places.
    Anyway I just left it and it seems fine with the original battery. Must just have been a bit low when I did the RNS510 firmware upgrade and having the ignition on for that long drains the battery quite a bit.
    Adelaide hills, SA
    Yes, SOME battery places are like that, but most/all of them should have the battery tester and know how to use it to reliably test the battery.
    edit: just looking at your signature, check the production date of your car and the past service record, making sure that the battery wasn't replaced already , the battery is most likely +4 years old, so based on that replacing it wouldn't hurt, (you could save yourself some inconvenience later).
