You need to find someone local with VCDS and have them scan your car.
There is no harm in upgrading (apart from the small risk whenever you upgrade anything that something could go wrong) it will at least have the latest software on there.
Be aware you will also need to reload your maps so have your maps disk on hand.
And it will delete the music on your HDD.
You'll have someone local with vcds. Try a local forum like briskoda.net or vwaudiforum.co.uk or autostadt.ie
So update to this.
I've downloaded the FW and made an ISO image however when installing it I get the following error:
I've downloaded a recovery FW that I found somewhere else and it got it back to a state with no errors (FW isn't actually usable though, just there to recover after error like this)
After I got it back I tried again, same result, and then I tried an old disk I had with 4020 on from the last time I updated a year or 2 ago and it had the same issue.
Would this be caused by the mismatch I have shown earlier?
My part number is 1T0035680D and currently have FW 4120 on it.
However I saw on another site that my part number equates to HW Vehicle 0xC801, 0xCA01 or 0xCC01
But my problem is on my system info I have a HW vehicle of 0xC201.
Unfortunately that's likely faulty hardware. Unless you are handy with reading and writing eeproms you're best sending your unit for repair to someone like rns510repairserviceuk124.bravesite.com
