Results 31 to 39 of 39
Thread: Help with RNS510
    Quote Originally Posted by aka666 View Post
    Hi�� my RNS510 keeps restarting, only shows the VW welcome screen then reboots again as a cycle. Few days back it made it to the menu after like 5-10 minutes of rebooting, did a system reset, didn’t help as now it only reaches the welcome screen.
    Can’t access the secret menu for the version. it is a EOS 2014 from Portugal.
    Any suggestions? Thank you in advance.
    Try loading the 'josi fix' firmware. Then if the the unit is able to boot up, load 5238 ORIG.
    If after loading the josi fix image the unit is still not able to boot then you likely have a hardware issue with the unit
    Files are linked here:
    Volkswagen RNS 510 Firmware Download Repository | my-gti.com
    Mar 2018
    Portugal
    Hi Kamold ,
    Which Josi fix should I try ?
    “1xxx/2xxx firmware
    Download: Location 1
    Filename: 2760_sk_fix.rar
    Or
    “3xxx/4xxx firmware
    Filename: 4020_sk_fix.rar
    (thanks to Josi for these fixe)” or other?
    Thanks in advance.
    Use the newer one
    Mar 2018
    Portugal
    Use the newer one
    Hi again 🙂
    So I tried :
    “3xxx/4xxx firmware
    Result was Gateway Error etc
    Then I tried:
    “It will attempt to restore a new SWL process and will enable it to boot up. (Thanks again to Josi)
    Download Location 1: swl_fix.iso (3.75MB)”
    Result was: ERROR 010301
    Any thoughts ?
    Hi again Help with RNS510
    So I tried :
    “3xxx/4xxx firmware
    Then I tried:
    Any thoughts ?
    Make sure you are burning at slowest possible speed using imgburn or cdburnerxp
    Mar 2018
    Portugal
    Hi,
    I burned at *4 with imgburn, shows same
    ERROR 010301 .I tried the fix and the 5238 same result.
    Now when starts up it says: The System is not able to start up.
    Please insert SWL-CD.
    Any suggestions ?
    Try DVD+R media instead of CD
    Mar 2018
    Portugal
    Thank you I will try Verbatim, is it better to try Rewritable DVD or normal ?
    More precisely which fix should I try before loading 5238, as I saw there are 3 different ones ?
    “Unofficial SWL recovery CD
    Or under
    “Skoda Columbus (RNS 510) Fix
    1xxx/2xxx firmware
    3xxx/4xxx firmware
    (thanks to Josi for these fixes)
    Much appreciated 🙂
    Or under
    1xxx/2xxx firmware
    3xxx/4xxx firmware
    Much appreciated Help with RNS510
    Try the last one.
    I would use write once rather than rewritable.
