Results 21 to 30 of 39
Thread: Help with RNS510
  1. #21
    No the hard drive is not related.
  2. #22
    Feb 2018
    Townsville
    Hello, i have problem with a RNS 510 in an amarok i have recently purchased. Every time i turn on the vehicle i get a message saying the desired language could not be loaded, then another saying "The language could not be changed. No voice out possible please try to reload the required language". Once I hit ok everything works except the voice out. I have updated the map pack since these photos which did not help. I also downloaded the next firmware available 5274 but am uncertain of trying it due to stability issues i have read about and the possibility of losing my reverse camera and mfd. I have purchased a ross tech vcds lead and can access the CAN bus but was wondering if anyone has seen this before or can help with a solution.
    My unit is a 1T0035680L, H09, 5269.
    Thanks for your help anyone.
    Help with RNS510-rns-510-2-jpgHelp with RNS510-rns-510-1-jpgHelp with RNS510-rns-510-3-jpg
  3. #23
    What if you go into language and select English (male) or English (female) whichever one you didn't have loaded before?
    It should then prompt for the map CD to load the required files if they aren't found.
    Failing that I would reload the firmware.
    Yes there are some units that seem to have stability issues with 5274.
    5238 is the most widely stable version across all units.
    To load this you will need to enable software downgrade in the secret menu, or follow the prompts when trying to load a previous version.
  4. #24
    Mar 2018
    Portugal
    Rns510
    Hi🙂 my RNS510 keeps restarting, only shows the VW welcome screen then reboots again as a cycle. Few days back it made it to the menu after like 5-10 minutes of rebooting, did a system reset, didn’t help as now it only reaches the welcome screen.
    Can’t access the secret menu for the version. it is a EOS 2014 from Portugal.
    Any suggestions? Thank you in advance.
  5. #25
    Quote Originally Posted by leeves75 View Post
    I think what might fix this is to load a 'factory' firmware image. This will delete EVERYTHING on the unit including the coding, maps, media, settings etc. But should also hopefully load all the files correctly.
    Try the 'ORIG' version of 5238 linked off Maverick's site:
    Volkswagen RNS 510 Firmware Download Repository | my-gti.com
  6. #26
    Quote Originally Posted by aka666 View Post
    Hi�� my RNS510 keeps restarting, only shows the VW welcome screen then reboots again as a cycle. Few days back it made it to the menu after like 5-10 minutes of rebooting, did a system reset, didn’t help as now it only reaches the welcome screen.
    Try loading the 'josi fix' firmware. Then if the the unit is able to boot up, load 5238 ORIG.
    If after loading the josi fix image the unit is still not able to boot then you likely have a hardware issue with the unit
    Files are linked here:
  7. #27
    Mar 2018
    Portugal
    Hi Kamold ,
    Which Josi fix should I try ?
    “1xxx/2xxx firmware
    Download: Location 1
    Filename: 2760_sk_fix.rar
    Or
    “3xxx/4xxx firmware
    Filename: 4020_sk_fix.rar
    (thanks to Josi for these fixe)” or other?
    Thanks in advance.
  8. #28
    Use the newer one
  9. #29
    Mar 2018
    Portugal
    Use the newer one
    Hi again 🙂
    So I tried :
    “3xxx/4xxx firmware
    Result was Gateway Error etc
    Then I tried:
    “It will attempt to restore a new SWL process and will enable it to boot up. (Thanks again to Josi)
    Download Location 1: swl_fix.iso (3.75MB)”
    Result was: ERROR 010301
    Any thoughts ?
  10. #30
    Hi again Help with RNS510
    So I tried :
    “3xxx/4xxx firmware
    Then I tried:
    Any thoughts ?
    Make sure you are burning at slowest possible speed using imgburn or cdburnerxp
