Could someone have a look of a scan taken after a retrofit Of an RNS5510 to a Golf MK VI I now have a few fault codes,I have looked through a lot of forums and now are becoming a little confuse .I think the main problem is with the CAN controller
Any help would be greatly received .I have removed the items from the scan that tested OK as to fit it on this page.I needed to activate a few settings to get the Nav to work but voice control won't work may be this needs a wiring mod but not sure at this stage.
Mick
Saturday,28,July,2012,09:22:16:12659
VCDS Version: Release 11.11.3 (x64)
Data version: 20120401
Chassis Type: 7N0
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZCP009920
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Sporadic communication error 1000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 AT HW: 03L 907 309 R
Component: R4 2,0L EDC H23 7266
Revision: 42H23--- Serial number: 00000000000000
Coding: 001D0012042500080000
Shop #: WSC 00028 028 00074
ASAM Dataset: EV_ECM20TDI01103L906018AT 003010
ROD: EV_ECM20TDI01103L906018AT_VW36.rod
VCID: 7CD92BD8F7F0469
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 057 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2706
Revision: 05351113 Serial number: 00001106051051
Coding: 0000020
Shop #: WSC 00028 028 00001
VCID: 171314742696851
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 F HW: 1K0 937 084 F
Component: BCM PQ35 B 110 0651
Revision: 00110 AC
Coding: 40180A3A802518C0400800C0340000E449510288536D816064 8000200040
VCID: 3147CAEC68327B1
Subsystem 1 - Part No: 5K2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 25051 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 170611 05 54 0403
Coding: 0230AD
1 Fault Found:
00907 - Intervention load Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 3
Reset counter: 235
Mileage: 5455 km
Time Indication: 0
Date: 2012.14.17
Time: 08:58:44
Freeze Frame:
Term 15 On
Voltage: 11.55 V
ON
ON
Term 50 Off
OFF
OFF
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 120611F2003756
Coding: 350003
VCID: 354FFEFC9C5A571
3 Faults Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 4310 km
Time Indication: 0
Date: 2011.14.20
Time: 17:04:54
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 254
Mileage: 4310 km
Time Indication: 0
Date: 2011.14.20
Time: 17:09:20
03272 - Control Module for Audio Interface
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 4310 km
Time Indication: 0
Date: 2011.14.20
Time: 17:04:54
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660234330
Coding: 010000
VCID: 2977228C40E2031
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 F HW: 1T0 035 680 F
Component: RNS-MID H61 4020
Revision: AB001001 Serial number: VWZ6Z7L7227132
Coding: 00000402040000A00000
Shop #: WSC 00020 790 12345
ASAM Dataset: ------------------------- ------
4 Faults Found:
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 34
Reset counter: 14
Mileage: 4304 km
Time Indication: 0
01523 - Microphone for Telephone (R3
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 128
Reset counter: 235
Mileage: 0 km
Time Indication: 0
01305 - Databus for Infotainment
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 6
Reset counter: 19
Mileage: 0 km
Time Indication: 0
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 34
Reset counter: 14
Mileage: 4304 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 235
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 19
Mileage: 0 km
Time Indication: 0
End ---------------------------------------------------------------------
I think your coding for diagnostic interface in wrong and also coding for RNS 510 is wrong. What is installed in the car eg: phone kit?? Media in?? Reverse camera?? Need to know what you have and don't have installed to figure out correct coding.
