Results 1 to 2 of 2
Thread: Help needed with CAN GATEWAY
    Jul 2012
    Nundah Qld
    Could someone have a look of a scan taken after a retrofit Of an RNS5510 to a Golf MK VI I now have a few fault codes,I have looked through a lot of forums and now are becoming a little confuse .I think the main problem is with the CAN controller
    Any help would be greatly received .I have removed the items from the scan that tested OK as to fit it on this page.I needed to activate a few settings to get the Nav to work but voice control won't work may be this needs a wiring mod but not sure at this stage.
    Mick
    Saturday,28,July,2012,09:22:16:12659
    VCDS Version: Release 11.11.3 (x64)
    Data version: 20120401
    Chassis Type: 7N0
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
    VIN: WVWZZZ1KZCP009920
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: Sporadic communication error 1000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 1010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 AT HW: 03L 907 309 R
    Component: R4 2,0L EDC H23 7266
    Revision: 42H23--- Serial number: 00000000000000
    Coding: 001D0012042500080000
    Shop #: WSC 00028 028 00074
    ASAM Dataset: EV_ECM20TDI01103L906018AT 003010
    ROD: EV_ECM20TDI01103L906018AT_VW36.rod
    VCID: 7CD92BD8F7F0469
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 057 A HW: 02E 927 770 AL
    Component: GSG DSG AG6 511 2706
    Revision: 05351113 Serial number: 00001106051051
    Coding: 0000020
    Shop #: WSC 00028 028 00001
    VCID: 171314742696851
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 084 F HW: 1K0 937 084 F
    Component: BCM PQ35 B 110 0651
    Revision: 00110 AC
    Coding: 40180A3A802518C0400800C0340000E449510288536D816064 8000200040
    VCID: 3147CAEC68327B1
    Subsystem 1 - Part No: 5K2 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer 25051 26 0512
    Coding: 009795
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 170611 05 54 0403
    Coding: 0230AD
    1 Fault Found:
    00907 - Intervention load Management
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 235
    Mileage: 5455 km
    Time Indication: 0
    Date: 2012.14.17
    Time: 08:58:44
    Freeze Frame:
    Term 15 On
    Voltage: 11.55 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 H HW: 1K0 907 951
    Component: J533 Gateway H42 1620
    Revision: H42 Serial number: 120611F2003756
    Coding: 350003
    VCID: 354FFEFC9C5A571
    3 Faults Found:
    01304 - Radio
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 245
    Mileage: 4310 km
    Time Indication: 0
    Date: 2011.14.20
    Time: 17:04:54
    01044 - Control Module Incorrectly Coded
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 254
    Mileage: 4310 km
    Time Indication: 0
    Date: 2011.14.20
    Time: 17:09:20
    03272 - Control Module for Audio Interface
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 245
    Mileage: 4310 km
    Time Indication: 0
    Date: 2011.14.20
    Time: 17:04:54
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
    Component: SG EXT.PLAYER H13 0240
    Revision: A1001003 Serial number: 7660234330
    Coding: 010000
    VCID: 2977228C40E2031
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 1T0 035 680 F HW: 1T0 035 680 F
    Component: RNS-MID H61 4020
    Revision: AB001001 Serial number: VWZ6Z7L7227132
    Coding: 00000402040000A00000
    Shop #: WSC 00020 790 12345
    ASAM Dataset: ------------------------- ------
    4 Faults Found:
    02873 - Control Module for Back-Up Camera (J772)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 34
    Reset counter: 14
    Mileage: 4304 km
    Time Indication: 0
    01523 - Microphone for Telephone (R3
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 128
    Reset counter: 235
    Mileage: 0 km
    Time Indication: 0
    01305 - Databus for Infotainment
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Mileage: 0 km
    Time Indication: 0
    00862 - Antenna for GPS Navigation (R50/R52)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 6
    Reset counter: 19
    Mileage: 0 km
    Time Indication: 0
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 34
    Reset counter: 14
    Mileage: 4304 km
    Time Indication: 0
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 235
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 6
    Reset counter: 19
    Mileage: 0 km
    Time Indication: 0
    End ---------------------------------------------------------------------
    Jul 2011
    I think your coding for diagnostic interface in wrong and also coding for RNS 510 is wrong. What is installed in the car eg: phone kit?? Media in?? Reverse camera?? Need to know what you have and don't have installed to figure out correct coding.
