Results 1 to 10 of 12
Thread: Help needed - Bluetooth audio issue with RNS510 install in MY12 Passat
    May 2012
    Hi
    I've just had an RCD510 replaced with RNS510 in a B7 Passat and everything is working fine except for the audio when playing music from iPhone 4s via Bluetooth connection. The song title/artist displays and appears to be playing but there is no sound. Audio works fine when making/receiving phone calls and for radio and navigation - it is just the bluetooth media that has a problem. Playing music from the phone also works when connected via MDI with cable.
    Does anyone have a suggestion on how to fix this?
    Dec 2008
    Sydney/Canberra
    Have you tried another (non-Apple) device to stream Bluetooth audio?
    I have a feeling this is an Apple issue, but I could be wrong.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    May 2012
    Thanks, Ill try that but the phone was working properly with the RCD510 - this only became a problem once the RNS510 was installed.
    Sydney,NSW
    Where did you get the rns installed? And how much pls
    May 2012
    I've tried it with a non-Apple device and having the same issue.
    Does anyone have any other ideas please?
    ---------- Post added at 06:15 PM ---------- Previous post was at 06:12 PM ----------
    Quote Originally Posted by cru22z View Post
    I had already purchased the rns & a reversing camera - installation for both around $400 (Marty & fhrx)
    Dec 2008
    Sydney/Canberra
    It might be a coding issue.
    Might just need a tweak of some options within the RNS510's control module with VAS-PC/VCDS.
    '01 Beetle 2.0
    Jul 2009
    Just call Marty and ask him, I'm sure he will be happy to help you sort it out.
    Jun 2012
    Ballarat Victoria
    Hi,
    I have exactly this problem with an Iphone 4 and RNS510..
    No sound but otherwise songs & artists appear?
    Looking forward to anyone who can suggest a fix.
    Dec 2009
    What firmware rev is the RNS running and what version Bluetooth module?
    Dino.
    SQ5 V6TDI | 911TT | Polo 6C
    May 2012
    Hi
    I've managed to fix the issue by upgrading the firmware. Was on 2840 and upgraded to 3810 - now working perfectly.
    Thanks to everyone for their help and suggestions.
