Results 1 to 10 of 13
Thread: Help!! MK3 VR6 Aftermarket speakers
    Feb 2006
    Devonport, Tasmania
    hey guys.
    I need some help please.
    I got some brand new 6 1/2" Alpine Type R coxial speakers for the VR6.
    Installed them tonight and the sound was distorted. Notice on the speaker box saying that if you have OEM tweetersyou have to disconnect em. OHHH i thought. So i disconnected em. Then there was no sound. So i checked out the bently manual wiring diagram for the stereo, joined the wires of the OEM tweeters together so they bypassed the tweeters. left the tweeters unplugged. There was sound but it was distorted like the first time I tried it.
    What should I do??
    2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
    1986 SAAB 900 Turbo 16 S
    Point Cook, Vic
    from memory VW in their infinate wisdom wired up the woofers in the door via the tweeters which have an inbuilt resistor.
    When i put my MB quarts in i had to wire direct from the head unit to the crossover. and then from the crossover to the doors and up to the tweeter seperately.
    Id jsut wire yours from scratch. would probly be easier.
    Feb 2006
    Devonport, Tasmania
    I thought I was completely bypassign the tweeters when i bridged the wires together.
    Tims right, the factory wires the woofer via the tweeter.
    Not sure if this would help.
    Currently my diagram is..
    Headunit --> OEM tweeter --> cross over --> (aftermarket) woofer and tweeter.
    Therefore I am running 2 set of tweeters an no problems. BUT if I unplug the OEM tweeter, the aftermarket setup does not work at all !!!
    Make sure the woofer connects to woofer and tweeter to tweeter on the crossover, I had that wrong and the sound was really soft and distorted at the woofer. GOOD LUCK
    Aug 2006
    Skye, Victoria
    the tweeter acts as a bridge for the woofer wiring, the only "crossover" in the tweeter is a capacitor filter for the tweeter.
    I dont see how re-joining the plugs as if they were plugged directly into each other would not work.
    Also the only distortion you "should" hear after installing your speakers the way you did originally "should" have been your factory tweeter.
    Feb 2007
    Bunyip, Victoria
    How loud have you got the stereo when this distortion apears? I take it you dont have an amp.
    Feb 2006
    Devonport, Tasmania
    Thats exactly what I thought. Thats why im confused.
    The stereo isnt any louder than when I had the OEM woofers in. In fact the OEM speakers work even better then the alpines currently. Thats is strange.
    No I dont have an amp. I didnt think I needed one. Theyre not Super Dooper speakers.
    Point Cook, Vic
    do your factory woofers distort if you plug them back into that same way the alpines are distorting from?
    Feb 2006
    Devonport, Tasmania
    I dont know. I havnt tried that yet. Wont be able to try it tonight or 2moro tho. Im not using the speakers for the time being. What are the chances of the speakers being faulty?
    Not likely? lol
    Point Cook, Vic
    Im more thinking along the lines of just proving whether your wiring is good or not.
    If they still distort then the wiring is the prob.
