Results 1 to 5 of 5
Thread: Half the DVD's I have don't play, why?
    Feb 2009
    Kingsgrove, NSW
    Hi,
    I have an rns-510 and half the time I put a dvd, it shows a message wrong region code!!!!
    Note : I've put the rns 510 myself and don't have a Vag-Com cable. Does anyone know if there is a coding issue or ...??
    and also who in sydney could actually fix it for me in sydney?
    Thanks!
    Dec 2007
    Brisbane, Southside...
    Whereabouts did you get the unit from. Australia is Region 4 encoding on our DVDs.
    http://en.wikipedia.org/wiki/DVD_region_code
    I would hope that with VAG-COM you would be able to change the region that the unit can play similar to what you can do with computer dvd drives and stuff. I'm sure someone on here will no how to change it if you can and be able to point you in the direction of someone with VAG-COM.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Jan 2008
    From the factory the RNS510 is set to Region 2, go back to VW and get it changed to Region 4 via VAGCOM
    Feb 2009
    Kingsgrove, NSW
    ok I've called Skoda ( they have no idea )... I don't know what to do now, I don't have a VAG COM cable. Is there anyone around Sydney that can help me out with my little problem ?
