Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
Thread: GPS is off
  1. #31
    Apr 2010
    I've disconnected my battery plenty of times, some for quite a duration. Never been asked for it except for when I first retrofitted it (I have the code card with me delivered with the unit from ebay).
  2. #32
    Dec 2009
    Kew, VIC
    Mk 6 Golf and later can be disconnected without a problem, as can many other models — it should be mentioned in your handbook.
  3. #33
    Jan 2013
    Yeah sorry wrote it and changed some and didnt realise it was you I was replying to till later.
    Sounds like either something has come loose or software has got its knickers in a knot
    Strange that it can see the satellites but not lock onto them.
    I downgraded the fw today to 3810 (GPS is still not working) and I have a strong suspicion that my antenna is disconnected at the antenna end. Now it shows 0/0 satellites so it doesnt see them, doesnt connect to them. That number of seen satellites previously was the last seen satellites when it was working. So if the unit actually doesnt see the satellites, means the highly likely the antenna is either faulty (factory sharkfin) or disconnected. The theory about the head unit sw has got "crazy" is not likely the case in my opinion, because the unit was working perfectly for a month.
    I have a hypothesis: a week ago I pumped up the wheels to 250kPa, (usually it should be around 230) but then didnt carry anything heavy so the car became much more sensitive for road imperfections and therefore the bigger vibrations could cause my loose antenna connection.
    I am pretty sure disconnecting the battery will not solve the problem as well so I am looking forward bringing the car to VW next week and they will tell me what is the issue.
    Ps. I also went through the radios and some of the channels (like Nova), which were crystal clear before, now has a little bit of static noise in the background, which means possible antenna issue, because the radio antenna and the GPS antenna is integrated.
    MY18 VW Tiguan Comfortline
  4. #34
    Jan 2013
    Quote Originally Posted by FJ Steve View Post
    So..moral of the story is...yes, I believe you will need the code.
    Checked the manual of the RNS510 and on page 9 it says, you will only need the code if you put the radio into another car. It also says if you disconnect the battery and reconnect it it would not ask for the code. Anyway I will not do this as I think it will not help.
  5. #35
    Sep 2010
    Um...just putting my experience in....
    That shouldn't happen. The RNS remembers your car (by an ID number of some sort) and it's only if installed in another car that the code is required.
  6. #36
    Mindarie, Perth (WA)
    Quote Originally Posted by wandersen View Post
    I know it shouldn't happen. But it did, and I felt the thread needed the experience from the other other side of the argument
  7. #37
    Jun 2011
    sydney
    ill put my money on a failed shark fin.
  8. #38
    Pacific Paradise QLD
    It could be you disturbed the wires in the plug that goes into the headunit.
    Much more likely than problems at the aerial end which wasnt touched.
    I would carefully check all of them. before attacking the aerial end
  9. #39
    OP stated in post #10 that he checked the rear of the RNS and all appeared ok.
  10. #40
    I was thinking more of where the wire goes into the connector Have seen more than one like this when pulled out incorrectly has either fractured or bent and separated the wires from the connector Would need metering out for connectivity Only takes one strand of a shield on coax to short it out as I have found to my sorrow
