Saying things shouldn't break never solves problems though Gotta try all possibilities to isolate exactly where the problem lies. I've heard of antenna stop working before (granted they were retrofitted though) and they're not all that expensive/difficult to replace (although you wouldn't be using the sharkfin location again).
But of course if it's a factory fitted item and you're under warranty, let the dealer take care of it.
Have you tried a complete power down and restart (disconnect battery for a few minutes?)
Graphite Blue TDI| DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs| Full LED interior|US GLI paddle shift MFSW|Carbon Vinyl wrapped trims|Colour Coded Votex Body Kit|
Can be. But it can also just measure the resistance and that means a disconnected antenna would not make a big change in the measurement. Or the measurement is just a simple resistance YES or NO, i.e. it would only measure if cable is connected at the back of the unit or not. Just guessing.
Will only ask for a code if you connect it to another car
Um...just putting my experience in....
Had the dealership change the battery in my R32 a few months ago. D*ck-heads didn't hook up a standby power source, so everything in the car powered down and lost connection.
Installed new battery, powered up...Ba-Bow..>RNS required a code. Head Tech came running out explaining that the internet connection to Wolfsburg was down and they couldn't tap into the factory archives to see what the code for the unit was. I said "well, you'd be stuffed anyway, because the RNS is not OEM, had it installed about a year ago - do yourself a favour and have a look inside the owners manual folder...there's a card there that may interest you"
*sigh*...seems we have to do so much for dealerships these days.
So..moral of the story is...yes, I believe you will need the code.
