My GPS is completely off today, I reset the RNS510 three times and still my position is Kms away from the reality on the map. I was driving in Sydney from CBD to Homebush and according to the GPS I was driving across the water, houses, etc.
Has anyone experienced similar behaviour?
MY18 VW Tiguan Comfortline
It's factory installed however I removed it a month ago when installed the Bluetooth unit. It was working fine till today. I suspect too that the antenna connection might became loose.
I am not keen to remove the unit again.
I don't think you will have an option. Do you have access to the hidden menu? If you can get to the final menu (ie the one AFTER AM/FM/version) then you should be able to see if the antenna is connected. Also, if you press the MAP button a second time, you should get a window come up which can show the GPS reading. ie number of satellites tracked vs number seen by the unit. If the unit is seeing the satellites but not tracking them then it may be the unit is having trouble processing the information which is usually a sign the antenna is badly positioned. If it is not seeing anything at all, then you're probably disconnected. Hopefully this helps.
Graphite Blue TDI| DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs| Full LED interior|US GLI paddle shift MFSW|Carbon Vinyl wrapped trims|Colour Coded Votex Body Kit|
Checked both and it doesn't see the satellites. I am taking removing the unit tomorrow.
Good hint on the satellites. I never knew that one.
Sent from my RM-821_apac_australia_new_zealand_304 using Board Express
08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
http://photobucket.com/gregsr32
Thanks for the help Buckets I will let you know when I finished with it.
Just finished and I couldn't find the problem, the connection seems okay at the back of the RNS.
I had a look again at the setup and it says GPS antenna connected, however it doesn't connect to the satellites. Bugger.
I think I will bring it to VW Barloworld soon to be fixed.
