Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 49
Thread: GPS is off
    Pacific Paradise QLD
    Quote Originally Posted by PeteC View Post
    Just finished and I couldn't find the problem, the connection seems okay at the back of the RNS.
    I had a look again at the setup and it says GPS antenna connected, however it doesn't connect to the satellites. Bugger.
    I think I will bring it to VW Barloworld soon to be fixed.
    Have you taken it for a drive to see if it can find any or are you still in the garage???
    ALso might need to do a reset by pressing Both left hand an the right hand button all at once
    Jan 2013
    I was outside when I removed the unit and checked the connection. I will try the reboot tomorrow and the factory reset plus your reset. Lets see if one of them helps.
    MY18 VW Tiguan Comfortline
    My method is more a hard restart than a reboot Try it first then a reset if needed Sometimes it needs to go for a drive to orient itself Mine did after last update and took about a K.
    Apr 2008
    Have you updated the firmware at all Pete? This same thing happened to me when I updated to 4120. It came good for a while when allowed to sit in the open to get the satellite fix then my antenna moved, so I had to play around again. Otherwise I am out of ideas. With factory RNS the sharkfin shouldn't be obscured.
    Funny thing is, it is acting just like mine was when the antenna had slipped further into the dashboard and wasn't getting a proper signal on the satellites.
    Graphite Blue TDI| DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs| Full LED interior|US GLI paddle shift MFSW|Carbon Vinyl wrapped trims|Colour Coded Votex Body Kit|
    Jan 2013
    Yes I have the latest 4120 firmware. I updated it a month ago.
    Jan 2013
    Unfortunately none of the resets helped. I am bringing the car to VW soon.
    Apr 2010
    I assume you've gone for a 10+ minute drive recently as that can calibrate it and fix it (I've had to do it when installing the RNS for the first time and following one particular firmware upgrade).
    Otherwise you could try buying an antenna for the RNS that sits inside the dashboard via ebay.
    GPS Antenna VW RNS 310 RNS310 RNS 510 RNS510 MFD3 | eBay
    Apr 2008
    I'm not sure a replacement antenna would do anything for him Ryan. The RNS is "seeing" the satellites but not tracking them, the antenna is showing connected in the secret menu, and the RNS was factory fitted, so it has a sharkfin antenna - no obscuration of signal.
    Jan 2013
    Quote Originally Posted by Buckets View Post
    What about if the cable is disconnected at the antenna end under the roof? Would the RNS still show it as "connected" because the cable is connected at the back of the unit?
