Results 1 to 6 of 6
Thread: Radio Install
    Nov 2009
    Radio Install
    I am looking to swap out RCD500 for RCD510, can anyone point me in the direction of someone (experienced) in Melbourne to do the install or at least update the vagcom coding - whatever that is!
    Nov 2007
    Quote Originally Posted by Sqeaky View Post
    Surelly it would be just plug and play - simple case of pull out your old and put in the new. I doubt that there would be any vagcom required....could be wrong.
    Jun 2009
    Quote Originally Posted by poyta View Post
    You may lose steering wheel controls if you upgrade.
    Also i believe you will need a canbus update if you are going from an RCD500 - RCD510.
    Might want to check out google to see if it can be done as a straight swap.
    Apr 2008
    Once you've done your research, drop me PM and we can sort something out. I've had mine (RCD300) out a couple of times (experimenting with the WD6050) and am awaiting delivery of my RNS so I will be on the tools again soon.
    Graphite Blue TDI| DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs| Full LED interior|US GLI paddle shift MFSW|Carbon Vinyl wrapped trims|Colour Coded Votex Body Kit|
    Feb 2010
    Hampton, VIC
    I am Melbourne bayside and can help with the coding if you need. Private, not a business
    It depends on what year you're driving. IIRC mid 08 and onwards should be fine, but anything built before that will usually require a new canbus gateway. I'm still investigating this myself as i've just purchased an RCD510 for my 06 GTI, but i've heard it may be possible to simply re-code the old gateway if you know what you're doing with a vag-com.
