Welcome to the forums.
The base head unit in the MK6 Golf R is the RCD510.
The RNS510 has Sat Nav (GPS) and a built in HDD to store MP3s.
Bluetooth is a separate independant function and option which can be connected to either the RCD510 or RNS510.
As per the MK6 Golf forum index thread, info on the Audio and electronics is in a separate subforum which I've moved your thread to. This is cause the headunits and bluetooth modules are shared between the models. You can find all the info you're after in other existing threads in this subforum. Cheers![]()
