Results 1 to 9 of 9
Thread: Golf MK7 MIB2 POI Collection Incl Known Police Enforcement Zones
    Oct 2010
    NW Sydney
    So you would like a Australia Wide MK7 MIB2 POI Collection Incl Known Police Enforcement Zones?
    Well here we go, this is further to this I have complied my most used POI's these include:
    SAFETY CAMERAS
    BP
    Caltex Woolworths
    7 Eleven
    Fixed Speed Cameras
    McDonalds
    Shell
    Red Light Cameras
    Mobile Speed Cameras
    Also includes Trapster data for Known Police Enforcement Zones in Australia
    However these are from September 2013 but still very valid!!
    All other categories are updated to the latest version as on poidb.com
    This is already converted to be copied over to a SD Card and imported, please note this will wipe all current POI's you have loaded so if you want the raw data in .KML files to compile yourself - PM me & make a donation.
    POI_BY_TUZII.zip - Google Drive - Google Drive
    Dropbox - POI_BY_TUZII.zip - Dropbox
    Use these files at your own risk as I accept no responsibility for any missed cameras etc.
    This has been tested on a MY 16 MK7 R, with 6.5" MIB 2 with version 0420 Maps, it should work with all Map versions
    Install instructions:
    Step 1: Extract the ZIP file to your SD Card - It must be extracted to the ROOT of the SDCard
    Step 2: Insert the SDCard into SD Slot 2 (in the glove box of your car)
    Step 3: Press the NAV button on your MIB II
    Step 4: Press Setup --> Manage Memory --> Update My POI's --> Update --> Select SD Card 2
    Enjoy
    Make sure you like and join Volkswagen Owners Sydney
    https://www.facebook.com/VolkswagenOwnersSydney
    https://www.facebook.com/groups/VOSydney
    ps. If you would like to make a donation as I saved you from a fine or a few, PM Me.
    "Forced induction" sounds like some sort of sexual assault.
    i drive a Golf 7R tuned by APR + exoticars
    Oct 2015
    Just tried it on my MY16 golf highline, works. Thanks
    Sent from my LG-H815 using Tapatalk
    Oct 2015
    How do I select which POIs show up by default?
    Oct 2015
    Also how do I turn off the tone that goes off each time I go pass one of the poi's.? Thanks
    Dec 2015
    Queensland
    Quote Originally Posted by frostywinter View Post
    The tone is built into the zip file. Its selected during the creation process. I am not aware of anyway to individually disable it for each poi except during the creation process. This doesn't mean that there isn't one though.
    EDIT: Here is a link on how to do it, it includes a link so you can choose your own poi's and make your own files. Its extremely easy. You can add mulitple POI files into the creation process.
    MIB II - Custom POI's / Speed Cameras etc
    Oct 2015
    Ok thanks for that, sorry to say but for me having that tone go off all the time which slightly turns down music volume each time is enough to stop me using these poi's, how do I remove them and go back to factory settings. Thanks.
    Jan 2013
    Hobart Tasmania
    I followed the instructions and successfully created a Personal POI file for the MIB 2.
    POIdb.com seems to be updated fairly often, its a fairly straightforward process to create a custom file with the POI groups you are interested in.
    The above link has an excellent how to...
    My16 Golf Alltrack, DAP
    MY18 Golf Comfortline
    Apr 2018
    Quote Originally Posted by tuzii View Post
    Can you change the distance from the POI to make the chime sound ?
    i.e 50 meters from POI, 100 meters from POI ?
    Nov 2013
    AUS
    Quote Originally Posted by FastMitch View Post
    No you can't.
    I find I get a tone 25m from the actual location so that is good enough for me.
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
