Results 1 to 10 of 12
Thread: Golf MK6 - Low Line Reverse Camera not working
    Sep 2017
    Western Sydney
    Hi All
    I know this topic has been covered many many many times, butno matter how many posts I read I still can’t find the solution to my issue..
    So I installed a “low line” camera to my 2013 GolfComfortline but I cannot get it to show anything on the screen. When I put thecar in reverse the radio unit does all the right things and changes to the reversecamera screen, but nothing shows up.
    Things I’ve tried so far:
    - Going over all the wiring and installation notesand can’t find anything wrong
    - I read some posts about the reverse signal beingpulsed by the BCM so I’ve put a replay on the camera as suggested
    - Reversed all my steps in VCDS and started fromscratch
    - I contacted the seller from Ebay who I got thereverse camera from and they said it’s probably because my unit is a RNS-MID,not a RNS-510. They said the camera will also work with the RNS-MID unit butthey don’t know how to modify the programming
    I guess it has something to do with programming as I get 2faults when I do a scan. 1 is the “37-Navigation -- Status: Malfunction 0010” andthe other is “56-Radio -- Status: Malfunction 0010”. It keeps complaining thatthere is a fault in the “Control Module for Back-Up Camera”, which doesn’t makesense as I installed a low line camera (without backup module). I have been tothe module installation list but that module is not ticked..
    Below I’ll post a pic of the camera I purchased from Ebay, a pic of the screen when the car is in reverse, VCDS screen shots and a dump from VCDS.
    Golf MK6 - Low Line Reverse Camera not working-3-jpg
    Golf MK6 - Low Line Reverse Camera not working-1-jpg
    Golf MK6 - Low Line Reverse Camera not working-2-jpg
    Golf MK6 - Low Line Reverse Camera not working-4-jpg
    Sep 2017
    Western Sydney
    VIN: WVWZZZ1KZDW098194 License Plate:
    Gateway Installation List: 7N0 907 530 AB
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Sep 2017
    Western Sydney
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
    VIN: WVWZZZ1KZDW098194 Mileage: 72670km-45155miles
    Sep 2017
    Western Sydney
    Address 01: Engine (J623-CTHD) Labels:. 03C-907-309-V1.clb
    Part No SW: 03C 906 026 AB HW: 03C 907 309 Q
    Component: 1.4l R4 TSI H02 3731
    Revision: LMH02--- Serial number: 00000000000000
    Coding: 00250012002400000000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_ECM14TSI01103C906026AB 001003
    ROD: EV_ECM14TSI01103C906026AB.rod
    VCID: 609AAA63BAC89DB73BA-8034No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 0AM-927-769.clb
    Part No SW: 0AM 300 058 P HW: 0AM 927 769 D
    Component: GSG DSG AG7 431 5272
    Revision: 00043014 Serial number: CU501209135878
    Coding: 0000020
    Shop #: WSC 46332 001 1048576
    VCID: 3E26341B6C7C8B47696-806A
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
    Component: ESP MK60EC1 H31 0152
    Revision: 00H31001
    Coding: 163B600D212B0002680C06ED841D0080310000
    VCID: 7DA4F3172DFA505F30C-8028
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 5K0 907 044 GJ HW: 5K0 907 044 GJ
    Component: Climatronic H19 1313
    Revision: 00001004
    Coding: 0010002002
    ASAM Dataset: EV_Climatronic A01010
    ROD: EV_ClimaAutoBasis_VW36.rod
    VCID: 79ACE70739526C7F1C4-802C
    Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
    Part No SW: 1K0 937 084 H HW: 1K0 937 084 H
    Component: BCM PQ35 B 111 0709
    Revision: AC111709
    Coding: 40180A3AE02518C0408800C0340000644B510288532D896064 8000200040
    VCID: 3330152F5B3E562F968-8066
    Subsystem 1 - Part No: 5K2 955 119
    Component: Wischer 24091 26 0512
    Coding: 009795
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 220912 05 54 0403
    Coding: 0630AD
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
    Component: AirbagVW10 013 0613
    Serial number: 003G5RAP3KP5
    Coding: 00004433
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
    ROD: EV_AirbaVW10SMEVW360.rod
    VCID: 313C1F27A1A2643FE44-8064
    Crash sensor for side airbag: driver side:
    Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H02 ----
    Serial number: 3572MSME0D685074ZZZ-
    Crash sensor for side airbag: front passenger side:
    Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Beif.V H02 ----
    Serial number: 3582MSME71405074ZZZM
    Crash sensor for side airbag: rear: driver side:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3512QSME4C472072ZZZT
    Crash sensor for side airbag: rear: passenger side:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3522QSME56241C3EZZZ$
    Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
    Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
    Component: Lenks.Modul 008 0080
    Revision: -------- Serial number: 90440LIK000AP
    Coding: 1882140000
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_A05.rod
    VCID: 76B6EC3B084C0307716-8022
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
    Component: E221__MFL-TK6 H07 0022
    Serial number: 70000000000000537347
    Coding: E20000
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
    Part No SW: 5K0 920 873 HW: 5K0 920 873
    Component: KOMBI H05 0705
    Coding: 170B00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
    ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
    VCID: 6D84C3577D1AC0DF80C-8038
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 AB HW: 7N0 907 530 AB
    Component: J533 Gateway H47 1633
    Revision: H47 Serial number: 030912F2000841
    Coding: 350003
    VCID: 70BADA236AA82D37ABA-8024
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H05 0705
    Coding: 000000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
    ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
    VCID: 6A8EC84B4CF4D7E7E5E-803E
    Sep 2017
    Western Sydney
    Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
    Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
    Component: SG EXT.PLAYER H18 0546
    Revision: A1001003 Serial number: 7663450435
    Coding: 010100
    VCID: 2A0E084B8CF417E725E-807E
    Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
    Part No SW: 1T0 035 680 F HW: 1T0 035 680 F
    Component: RNS-MID H61 4020
    Revision: AB001001 Serial number: VWZ6Z7L3290053
    Coding: 04010042010000A00000
    Shop #: WSC 05314 123 12345
    VCID: 313C1F27A122643FE44-8064
    3 Faults Found:
    02873 - Control Module for Back-Up Camera (J772)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 111
    Reset counter: 115
    Mileage: 67256 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 115
    Mileage: 67256 km
    Time Indication: 0
    01523 - Microphone for Telephone (R3
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 254
    Reset counter: 90
    Mileage: 67258 km
    Time Indication: 0
    Date: 2017.04.01
    Time: 18:58:14
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
    Part No SW: 5K0 959 701 H HW: 5K0 959 701 H
    Component: Tuer-SG 009 2106
    Coding: 0000756
    VCID: 3728213F4346BA0FAA0-8062
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 P
    Component: EPS_ZFLS Kl. 69 3305
    Revision: 00H22000
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
    Component: Tuer-SG 009 2120
    Coding: 0000756
    VCID: 323E102BA8245F279DE-8066
    Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 115
    Mileage: 67256 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 115
    Mileage: 67256 km
    Time Indication: 0
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 90
    Mileage: 67258 km
    Time Indication: 0
    Date: 2017.04.01
    Time: 18:58:14
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
    Component: Tuer-SG 007 2101
    Coding: 0000208
    Shop #: WSC 01357 011 1012551
    VCID: 35342B37594A481FB8C-8060
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
    Coding: 0000208
    VCID: 36362C3B444C4307B16-8062
    Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
    Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
    Component: TELEFON H15 3200
    Revision: 1B001001 Serial number: 00007663503960
    Coding: 0A01000000010101
    ASAM Dataset: EV_UHVNA 002720
    ROD: EV_UHVNA_002.rod
    VCID: 392C270779D2AC7F5C4-806C
    Sep 2017
    Western Sydney
    I’m really stuck guys, so any help would be greatly appreciated.
    Try this:
    In the RNS, turn OFF bit 6 in byte 3 for RVC backup camera low.
    Save the coding.
    Reboot the RNS.
    Go back into coding and turn the bit for RVC backup camera low back ON.
    Save coding.
    reboot RNS.
    Test.
    Sep 2017
    Western Sydney
    Try this:
    Save the coding.
    Reboot the RNS.
    Save coding.
    reboot RNS.
    Test.
    Hi Kamold,
    Thanks for the reply mate, unfortunately this did not work either.
    I ran a scan after I disabled bit 6 in byte 3 and it still faults with "02873 - Control Module for Back-Up Camera (J772)" even though it's technically not being requested. Is that right? Is it possible that programming has changed elsewhere when I enabled bit 6 byte 3 the first time, and that's why just changing byte 3 does nothing to fix the "02873 - Control Module for Back-Up Camera (J772)" fault?
    Thanks guys..
    Try the same for the canbus gateway installation list.
    Enable backup camera 6c.
    Turn car off and on.
    Untick backup camera.
    If it still doesn't fix it you have a cabling problem with your lowline camera.
    Sep 2017
    Western Sydney
    Hi Kamold,
    After what seemed to be about 900 times of ticking, in-ticking, rebooting and waiting... I finally have no 6c module errors. The bad news is I still have a black screen when I put it in reverse. I ripped the RNS unit back out and triple checked all the wiring and it all looks good, so I guess the camera is stuffed then?. I might try one of the RGB to composite converters on Ebay, just so I can run a normal composite camera (and also make it easier to change if it ever packs it in). Have you ever tried one of these converters or heard anything bad about them?
    Car Backup Camera Rearview RGB To AV Adapter Box for VW Volkswagen RNS510 RCD510 | eBay
    Again, thanks for all your help..
    Cheers,
    Iain..
