And finished version:
I dont think so but this would obviously need to be checked.
The good option is to do the upgrade in stages - 1. HL, 2. A-L and 3. Washers.
This will reduce the work load and the coin load level obviously and most probably the 2+3 can be DIY in a day as on a Golf all is ready for it.
After Install
I am based in Sydney and i'm considering getting the bi xenon headlight kit + rear golf R brake lights installed onto my mk6 GTI
how much would i be looking at for both installed??
thanks
Hi mate, every car is a bit different so each coding would be different.
If I provide you with incorrect coding it may destroy your BCM or other components.
BCM is responsible for voltage to all the electrical parts - if you code a part with wrong voltage... well I dont have explain what can happen.
We can code the lights for you Australia wide
