Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Golf 6 DRL LED Bi-Xenon Headlights - Brand new & Genuine OEM
    Jun 2012
    Maroochydore, QLD
    I dont think so but this would obviously need to be checked.
    The good option is to do the upgrade in stages - 1. HL, 2. A-L and 3. Washers.
    This will reduce the work load and the coin load level obviously and most probably the 2+3 can be DIY in a day as on a Golf all is ready for it.
    Jun 2012
    Maroochydore, QLD
    And finished version:
    Jun 2012
    Maroochydore, QLD
    After Install
    Mar 2013
    I am based in Sydney and i'm considering getting the bi xenon headlight kit + rear golf R brake lights installed onto my mk6 GTI
    how much would i be looking at for both installed??
    thanks
    Sunshine Coast, Qld
    Quote Originally Posted by liquidforce View Post
    After Install
    Hey Liquidforce,
    What coding did you use? When I installed mine all the coding that I tried didn't work. Only way I can get the DRL to work is to turn on the parkers... Any ideas?
    Jun 2012
    Maroochydore, QLD
    Hi mate, every car is a bit different so each coding would be different.
    If I provide you with incorrect coding it may destroy your BCM or other components.
    BCM is responsible for voltage to all the electrical parts - if you code a part with wrong voltage... well I dont have explain what can happen.
    We can code the lights for you Australia wide
    Quote Originally Posted by TeamCrash View Post
    Hey Liquidforce,
