Results 1 to 10 of 14
Thread: Fury's Stereo Install
    Aug 2008
    Vic
    Hey Guys,
    Figured you might be interested in seeing my install, so i'll post some of the build pics here. It's been a work in progress for quite some time now... I've been through a fair bit of equipment too, trying to find something I like the sound of Had a chance to tidy up the wiring last night, and will work on a false floor to finish off the boot shortly too.
    The system as it currently stands:
    Headunit: Alpine 7998r Phantom Face
    Processor: Alpine PXA-H900 F#1 Status
    Tweeters: ScanSpeak D2904-700000 Ring Radiators
    Midranges: Vifa P13WH-00-08 5.5" Midranges
    Midbasses: Peerless HDS PPB 830875 6.5" Midbasses
    Subwoofers: Oz Audio Matrix Elite 12"
    Speaker Amps: Arc Audio SE4200
    Subwoofer Amp: Arc Audio SE2300
    Front Battery: Optima D34 Yellow Top
    Rear Battery: FirstStart 55a/h
    Running wiring from front to rear:
    Attached Thumbnails Attached Thumbnails Fury's Stereo Install-7-small-jpg   Fury's Stereo Install-10-small-jpg
    Fury's Stereo Install-12-small-jpg
    Aug 2008
    Vic
    Tweeters in the A-pillars
    Attached Thumbnails Attached Thumbnails Fury's Stereo Install-25-small-jpg   Fury's Stereo Install-27-small-jpg
    Fury's Stereo Install-28-small-jpg   Fury's Stereo Install-36-small-jpg
    Fury's Stereo Install-34-small-jpg
    Aug 2008
    Vic
    Midranges in the kick panels:
    Attached Thumbnails Attached Thumbnails Fury's Stereo Install-32-small-jpg   Fury's Stereo Install-37-small-jpg
    Fury's Stereo Install-38-small-jpg   Fury's Stereo Install-42-small-jpg
    Fury's Stereo Install-43-small-jpg
    Aug 2008
    Vic
    The boot (more pics to come, hopefully tidier ):
    Attached Thumbnails Attached Thumbnails Fury's Stereo Install-41-medium-jpg   Fury's Stereo Install-44-medium-jpg
    Fury's Stereo Install-45-medium-jpg   Fury's Stereo Install-46-medium-jpg
    Fury's Stereo Install-47-medium-jpg
    Aug 2008
    Vic
    Psst, how do i get the images to show up in the post instead of as a link?
    I tried tags with no success, it still linked them?
    Jun 2008
    Hobart, TAS
    use the IMG code instead of the direct link code.
    I think that is correct, just copy past them individually until one loads in the thread.
    nice choice of headunit btw
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
    Mar 2008
    wow What a setup. Looks like you've put in quite a bit of effort there, well done! With regards to the speakers next to the pedals, are you putting a grill on top of those? I know my foot would be finding it at one point or another.
    Final pics of the boot?
    Quote Originally Posted by Fury View Post
    Upload on Imageshack (4-5 at a time if its too slow), then click for direct links, then put [img] tags around each direct link.
    Aug 2008
    Vic
    ^^ [img] test, just comes up as a link for me
    I don't have any issues with the midranges in the kicks where they are.
    My foot rests nicely on the footrest below the speaker, i've never kicked the driver. The passenger side is also slightly raised off the floor, so you can slide your foot up against it without any issues. Have been in for a while now and haven't been kicked, so i'm not terribly fussed. I've looked into grills in the past but haven't found anything I particularly liked that didn't have an effect on the sound. At one stage I was looking at door/drawer handles, but most I saw were too big/bulky or not the right size.
    I'll grab some pics of the tidied up boot when I get a chance. Still need to create a false floor to hide the amps, and tidy up the sub baffle so it's a bit more attractive.... Just need more time
    Jan 2008
    Sunshine Coast
    1. make sure you pick the right button on the reply screen.
    2. Post a DIRECT link into the pop up screen.
    3. I usually delete the auto "http:" that comes up in the pop up, as most direct links already have that.
    4. No doubt there's other ways, but this works for me!
    Aug 2008
    Vic
    If you check my post (reply to it), it has [img] tags around it.
    I think the problem is the software doesnt parse it unless it has an extension (eg: .jpg). As this forum is hosting them and linking to it without and extension, it doesnt like it.
    CBF uploading them to imageshack or the like... you can all click the links to view the pics i guess :p
