Yeah go with Transporter for OEM in Adelaide. All OEM units need to be coded to your car which requires VW dealer equipment or the VCDS. An installer will not have this or any knowledge of coding unless they are a VW specialist.
Also if you do buy from anywhere else online make sure it comes with the radio code which is required to code the unit to your car, otherwise the unit is just a paper weight.
