Results 1 to 10 of 13
Thread: Full panel display for MKV question
    Hi guru's.
    I have a 2008 GT Sport 1.4 twin charge with the standard radio mounted in the dash, as I couldn't justify the $2250 price for the full screen SATNAV option when I had a perfectly good NAVMAN at home.
    It's been a couple of years now, and I would really like to fit a full screen LCD panel (VW preferably, as I had some issues with an aftermarket system just after I got the car. It wouldn't allow me to retain all of my dash/steering wheel functionality. That was through JB, and from memory it was Alpine of Kenwood) into that slot on the dash.
    Honestly I'd be happy enough if it was just the radio/CD player with no SATNAV or reverse camera functionality, as I don't have that anyway, but am not sure what model I would need OR if it's a simple case of removing one and slotting in the other.
    Any thoughts or advice would be very much appreciated.
    Dave
    Adelaide hills, SA
    The RCD510 would be the cheapest option but the extra money for RNS510 is well worth. The RVC images look much better on hi res. screen which rcd510 dosn't have.
    Sunshine coast
    Also, you might need to upgrade your canbus gateway, to avoid battery drain. Check if your revision is rev. K or earlier, in which case you need an upgrade. There's lots of info if you search the forum.
    132TSI Tiguan Allspace
    Mar 2009
    UMG Brisbane
    +1 for the RCD510 - there is a thread here about which ones to buy so you can use the SD Card - I gave up on my SD card, but it works fine in my old mans skoda.
    Al..
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
    Jul 2010
    Robina Gold Coast
    Quote Originally Posted by iampivot View Post
    No need for an upgrade if its a 2008 model mine is a november /2008 and i had to trouble fitting a RNS 510
    Jun 2011
    Quote Originally Posted by ian View Post
    Not sure about that, I have an August 08 model and it came with RCD300. I'm assuming that means I have the older gateway though.
    Adelaide hills, SA
    Here is the thread that shows which canbus is OK and which one needs an upgrade http://www.vwwatercooled.org.au/foru...tml#post846268
    Aug 2011
    My friend has a MY08 GT Sport and his CAN Gateway was fine, he has a RCD510 and a MK6 Climatronic in there right now. Almost looks like a MK6 in there
    The screen/features of the RNS510 is much better, but the price/speed of the RCD510 can be hard to beat
    Thanks very much all. I'll check the CAN-Bus thread too thanks Transporter.
    Apologies if this is a noob like question, but can you get SATNAV on the RCD510? If not I'll be happy as is in audio mode, mbe BT. I don't have parking camera's or climate control stuff running through it as it's separate in the 08. I just want a bigger screen, prefer genuine Golf parts that work simply, install simply and allow me to retain ALL steering wheel control functionality.
    I assume any audio supplier/fitter can fit it and the new CAN-Bus if it's needed pretty simply?
    There are tons on Gumtree for sale...is this the best option for purchasing one of these units?
    Sunshine coast
    Just curious, short of actually doing an auto-scan, to get the current software revision on my gateway, is there any way to determine wether battery drain is occurring (except waiting for the battery to drain)? I'm in the process of upgrading to an RCD-310, and while I'm waiting for a micro-can cable, I've tried it out briefly. The unit turns on and off with the key in the ignition. Can it be that it's still not going to sleep properly when turning off the ignition?
