Results 1 to 10 of 12
Thread: FSI wired for below-seat amp?
    Sunshine coast
    Is an 2.0FSI golf MkV prewired so that one can simply install an amp beneat one of the front seats, or would one have to lay signal and speaker cables from behind the headunit and to the speakers?
    132TSI Tiguan Allspace
    Jan 2008
    Quote Originally Posted by iampivot View Post
    No it's not and yes you do.
    An easy alternative is the Blaupunkt P'n"P amps.
    Upgrading the audio with the stock headunit without the factory amplifier
    Feb 2009
    I've got the Blaupunkt under-seat amp from my Passat sitting in a box at home - are they all the same? No wiring for it though, but I imagine the wiring would be available from VWA and would be cheaper than the amp... no idea! LOL...
    Jan 2008
    That's the oem amp, these are designed for retrofitting and come with harnesses, no cutting or anything required all plug and play. They fit about 100 cars as well.
    Albion QLD
    So it is only the OEM amp that comes plug and play? I've got an old amp from our old 3 series that I want to use in my car..
    2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
    Feb 2009
    No harness with mine, they just gave it back to me when they fitted the arc audio amp that I have.
    I need to dig it out and find the part number...
    Feb 2009
    OK, the amp is a 5K0 035 456 - Blaupunkt 8 channel amplifier, manufactured May 09, HW H06, software 0316. No wiring harness, but also with the metal bracket to mount to the floor of a Passat (or Golf V or VI, same part number) 1K0 035 883, and the black plastic piece to cover it all up under the front of the seat - 1K0 971 813 (also the same part number for a Golf).
    The amp is one of these: http://www.worldimpex.com/parts/genu...r_1754088.html
    Only thing is I have no cables like I said, and I have no wiring diagram for it...
    Jan 2008
    Quote Originally Posted by Swallowtail View Post
    Wiring diagram can be found here
    Volkswagen factory amplifier details and pin assignments
    http://www.my-gti.com/1271/volkswage...in-assignments
    Feb 2009
    No, it's different to that...
    Rough pic:
    Jan 2008
    Quote Originally Posted by maca View Post
    What I meant was the OEM amp is not plug and play, the amp I posted is designed for plug and play operation.
