Results 1 to 5 of 5
Thread: Fitting an RCD 510 into my 2008 Golf R32
    Mar 2017
    I am looking to fit an RCD 510 into my 2008 Golf R32 and i have a couple of questions...
    Given my car is a 2008 ( MY2008 ) car. I think i should have the updated 'L' or higher CAN module? So i shouldn't suffer the battery drain issues??
    And i have a full height MFA..... So other than the aerial adapter (i understand this is part number 7L6 051 551) I think my car should accept the unit without any need for coding/programming? Is this correct?
    So my main questions are - Given that i am fitting the unit for two reasons:
    1: The Bluetooth integration
    2: It looks much better than my factory RCD500
    1. Will i have to route a microphone cable for talking hands free? I don't relish having to do this, especially up the A-pillar trim where there are SRS airbags.
    2. I have a Samsung Galaxy S7 - Will i be able to Bluetooth music and/or will my factory (armrest mounted) Aux in still work?
    This is the very unit i am looking to buy:
    https://www.gumtree.com.au/s-ad/hill...dio/1184992089
    Regards - Richard.
    RCD510 doesn't on its own have bluetooth...its a seperate module that connects up to the RCD510. The microphone connects to this.
    Given what you want to achieve might I suggest instead looking at an RCD330g?
    This has integrated bluetooth, is much faster and has a more up to date interface, plus gives you access to Apple Carplay and Android Auto...
    Mar 2017
    Thanks Kamold... I did consider the RCD330G.
    But the RCD510 i have seen (in the link on my post) is only a short drive from me, has the Bluetooth and he is very negotiable on price... I figured if i could pick it up for $200(ish) then that would be a good buy?
    Regards richard.
    Quote Originally Posted by richard300 View Post
    Regards richard.
    What is the part number of the Bluetooth module?
    The old ones don't support music streaming. If it's a 9w7 (premium Bluetooth) then by all means go for it as it will meet your requirements.
    If it's a 9w2 or anything aftermarket (except for mobridge they are actually good) then I think you will be happier with an rcd330
    Mar 2017
    Thanks for all the advice and feedback.
    So the RCD510 in the link didn't have the BT module that would stream music.
    And I managed to find a RCD330 for $199 (delivered)
    Hopefully it will be here next week.
    OEM VW RCD330 Plus Radio 6.5'' MIB UI Bluetooth USB AUX for VW Golf CC RCD510 6957999611844 | eBay
