Results 1 to 10 of 15
Thread: Fitting out Mk6 Golf with Nav / Bluetooth / Reverse Cam in VIC
    Jun 2015
    Keysborough
    Hi Guys,
    Recently picked up a 2010 Golf GTI in VIC. It has the standard RDC510 only with no MDI, no park sensors and basic bluetooth (answer and hangup calls only).
    I want to add Navigation, full bluetooth phone integration including music streaming and OEM fit reverse camera. I'm really confused about the way to go about this and would appreciate some advice or a shop in Melbourne South East that can quote me. I use the car for work so looking for a solution with full integration.
    Thanks!
    Talk to forum sponsor VW Central.
    They can sort it all out for you.
    Quote Originally Posted by mpearce38 View Post
    Hi Guys,
    Thanks!
    Bluetooth is easy - you need the premium 9w7 bluetooth box that goes under your seat. Should simply be a case of unplugging the current Bluetooth unit (assuming its the standard basic VW optioned Bluetooth) under your seat, and plugging the new one in.
    RNS510 is worth a fair bit of coin, and isn't a very good unit (slow and clunky and old design). Personally i didn't option the RNS in my car as i didn't see the value of it - but up to you.
    OEM reverse camera is something i wish i had optioned (only $500 option) when i ordered my Golf R, and always regretted not having it. Reversing at night is not easy in that car, especially with the woeful reverse light VW give you. Fitting a reverse camera aftermarket is somewhat involved and requires a fair bit of interior dismantling. Not a terribly hard job, just expensive and time consuming.
    If you are going to pay someone to install all this gear - you will be paying a pretty penny. OEM parts plus installation will probably see you around $3-4k.
    Jun 2015
    Keysborough
    thanks yeah costing the parts from the supplied website looks too costly for my wallet. So will need to rethink
    Think I will keep the rds510 and skip the Nav do the Bluetooth upgrade and see what is left for reversing cam. Also noticed they have an OPS sensor kit. I would prefer this to the cam but didn't think it could be retro fit has anyone tried installing this aftermarket?
    Go the reverse camera over the OPS kit. I had the OPS kit in my Golf R and they were annoying whereas the reverse camera is quite useful.
    Dec 2014
    Monaro, NSW
    It is an expensive setup, but what you originally proposed is exactly what I had done to my MkV Pirelli, and I couldn't be happier. The pop-up reversing camera is great (although this is a MkVI product, so some modification was required) and bluetooth pretty near perfect. With respect to the comment above about the RNS-510 being slow, old and clunky, that is true to a point, but it is also so well integrated into the car, that after my very extensive research, it was my best and favourite option. YMMV, but don't discount the RNS-510, which you can sometime find for sale on forums like this for much cheaper than retail or even grey-market, and so much the better if you are competent enough to install it yourself.
    Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
    Toy: 2008 GTI Pirelli | Sunflower Yellow | 3 Door | DSG | Pirelli Wheels | RNS-510 | 9W7 Bluetooth | RVC | Rear Sensors | Fog Lights | To Do: Mk7 Climatronics, MkVI MFSW, Colour MFD
    Jun 2015
    Keysborough
    Thanks,
    Installing the unit or blutooth module is not an issue, I would prefer the camera to be installed by someone else however, mainly because I'm time poor and fairly unlucky in these things and always losing a screw or snapping a piece.
    I did see Blaupunkt have a RNS-510 clone the Philadelphia 835 looks like a competent unit with Blutooth on board and will let me run external amps via a preout rather then off the speaker outputs. I will still need the OEM camera however, but i value this feature as currently our family car has it and if you get lazy it is easy to back out with out looking when driving the 2nd car.
    Also lots of Chinese branded replicas with Andriod but I'm not much of a tinkerer and value sound quality over lots of functions. the build quality would concern me also
    would be interested if anyone has any experience with any of the above
    Jun 2015
    Keysborough
    Quote Originally Posted by arcadelt View Post
    Hi I think I contacted you when i was hunting for yellow Pirelli. nothing eventuated down that path
    Dec 2014
    Monaro, NSW
    Ah, yes; so I guess the Sydney possibility fell through too...
    ...but you got a MkVI GTI instead, which is a very worthy alternative, and a year and one generation younger too - but, as I have found, those add-ons can certainly add up. If you want someone to do the installation, I second the recommendation for VW Central, but just make sure you are happy with everything before you drive out the door.
    I see there are now two yellow four-doors on Carsales.com, but still close to $20K.
    Jun 2015
    Keysborough
    No didn't work out, but wrapped with the Mk6 is in great condition. Did you buy the parts from VW central?
