Originally Posted by
Matt P
My setup is the amp as above, all wiring looms to suit the GTI 7 and a PP8E-Q subwoofer, all pro installed by a shop for $1400. Amp is under the passengers seat.
sound is significantly better even without changing speakers. Next step is to have my rainbow germanium components fitted and i expect to go up another level again
I wouldn't say that is a certainty - higher end drivers tend to have more power handling (largely irrelevant since you have bass redirected to the sub) and higher end tweeters will have extended treble response which is often too bright with the large glass area of modern cars. I know people who have done the full driver upgrade on various cars and, yes, they can run higher volumes if they aren't running a sub but most ended up padding down the tweeters (or even placing some filtering material over them) to make the treble tolerable.
Your sub is the most limiting item in your current setup - an 8" driver can only do so much (and being ported will increase and may possibly extend the output a touch, at the expense of group delay but it also adds to the size of the enclosure)
Matt P
see if you can have a listen to the pioneer sub first. I found most of those super tiny ones a bit boomy for my liking. OK if its in the boot, but if they're in the cabin it might not sound the greatest. If you can, i'd still load a 10" into the boot in a hidden enclosure or something.
^ This
Resident grumpy old fart
