FISCON Basic Plus/MFD problems...
Hi guys,
Extremely new to all this, I think I have it figured out but I am looking for confirmation...
I have (very) recently bought a 2010 Passat wagon with a Voice Control enabled RNS510 with Sat Nav. I installed the Kufatec Basic Plus unit yesterday and have mixed results. I had to install the Kufatec mic as well, is this normal? I would prefer just the one mic but I can live with that. My main issue is I do not have the Kufatec menu on the MFD... This means I can't set alot of things up. I have no skip control on my AD2P streaming (iPhone 6), I get a little pop noise as I take the key from the ignition & Siri and the VW Voice control seem to race each other at times. On the plus side, I have full phonebook and call list access, and streaming does work with excellent quality. The phone button on the steering wheel does nothing, the voice control button fires the Starter's Pistol for Siri and VW voice control.
Now, I have done no programming. Would the appropriate VCDS programming sort out these issues or do I not require further programming as I have the unit semi-functional & maybe I have missed a step? I have played around with the various activation codes in the Kufatec manual which seem to break it to varying degrees. I think my main goal must be the MFD menu. Thoughts?
- You may not post replies
- You may not edit your posts
Forum Rules
