Firmware upgrade for rns 510 - 2760
Hi All,
Thought I'd just let everyone know, just in case anyone was thinking about updating their firmware, that I updated my RNS 510 to version 2760 from:
Volkswagen RNS 510 Firmware Upgrade to version 2760 / 2762 / 2764 / 2766 / 2768 | my-gti.com
No issues and I am using V3 maps and I am able to use SDHC cards
(the main reason why I updated the firmware).
Cheers.
Hi l3lazin.
Hope you can help with a few questions, I want to do the same upgrade.
- What Model year is your VW ?
- do you know your RNS 510's version of Hardware and firmware before the upgrade ?
- Did you lose any music or your maps ?
- Did you have to reprogram the steering wheel controls after the upgrade ?
And lastly, did any of these work for you after the upgrade ?
- digital speed display on MFD
- Speed limit display on map
- shows clock when switched off
- dual zone controller Climatronic control
- Faster Startup
- SDHC 32 GB Support
a bunch of questions, I am just a little cautious before doing the upgrade.
Hi spanky,
Sorry mate, haven't checked the forums in a while, I will try and answer your questions the best I can, to the experience that I have with it:
2009 MKV GTI (the last of its kind)
Nope, I winged it, at work now but when I get home, I will post you the firmware and hardware versions, I was just banking on the fact that mine was the newest of the MKV.
NOPE!, it was just a firmware upgrade
NOPE!, no need to do that either.
Also to note, after the upgrade, the unit doesn't know where it is, so go for a drive and it should find itself. If not then force the restart by holding the 3 buttons, and you should be good to go!
Nope. Never did work.
Not sure what you mean, but mine are controlled by the dials.
- Faster Startup
Not really.
YES. This is the big draw card for me!, 32GB support!, one thing is, that after I turn off the car and come back, I get a SD CARD read error. I just have to push out the card and back in, and its happy again.
Time display on after upgrade
Hi
After my upgrade I was able to see the clock when the unit was off. You need to change the settings:
Setup->time display-> on
yeah thanks mate! So the clock works.
- You may not post replies
- You may not edit your posts
Forum Rules
