Thanks Hillbilly, DL'ing now.
Try this https://docs.google.com/file/d/0B3Cr...it?usp=sharing It comes up for me this time
Don't bother upgrading firmware yet as you'll have to reload after replacing the HDD...
hallo,
I did instal Firmware 412x - Link
However I did not sow the note that hv version must be higher than 3.
my is wel 3 and now i am having some problem that my power battery from the car is every day empty.
is there any solution to fix it. I did disconet my rns510 from the car. there is some information about rns510 in attachment. please anyone help.
Did you install the European version as the 4120 for Australia partitions the HDD differently and it wont then load a euro map as the partition is too small
By the link you have listed it appears you have the wrong firmware version if as it seems you are in Europe I see from your Newbies post you are in Holland so this will be the wrong version I would think. Someone may be able to point you to where you can get the correct Euro version
Check the vwnavi forums:
Unofficial 272x software and SWL recovery CD
thanks a lot
Thanks for the great write up, detailed instuctions and the .iso. My unit is now running the latest firmware and seems a little snappier, also loving the custom boot screen I got on there.
Easy as pie to do this update, cheers to all involved.
Question... have there been any updates since the 4020 release? I feel like I have been on this version for a lot longer than the time spent between other versions..
