I upgraded to the 38xx firmware and I can't load maps (put cd in, nothing happens, maps show up in settings as Aus/NZ but when I view navigation it doesn't show any terrain nor can it calculate paths). After about 10 minutes the entire unit locks up. Any ideas?
After you upgrade to 38xx you have to reload the maps.
It can take a while (up to 30 mins or so) and during that time the nav will be fairly unresponsive as its loading from the map disk rather than hard drive, so its slower. Also unless you have a satelitte signal (ie if you are in a garage) it wont be able to give a position, so will display a blank map.
Insert the map disk, wait a few mins and then press eject. It will warn you that its loading maps, and you can get a progress bar.
Yep, i did that. even with satellites locked an my location found, the map wouldn't go to my location. regardless, the device froze up and became completely unresponsive after 10 minutes or so, so I'm guessing my device must be too old for 38xx firmware.
Here's a handy tip for those with the secret menu enabled.
You can find both your GPS speed and your true Speedo speed, which is handy for long highway crusing.
To find your GPS Speed, go to the Secret Menu (Hold down setup for 20 seconds), then Navigation -> Matched Position, scroll down and you'll see the speed the GPS thinks you're doing. On my Polo this shows a 110 KM/hr when my MFD shows 117. I'd recommend having at least 4 sats/3D fix if you're relying on this to not get a ticket.
To find your true Speedo speed, go to the Secret Menu, then Navigation -> Dead reckoning, scroll down to CAN Speed.
This is what your car thinks it's going at. On my Polo this showed as 111KM/hr when my MFD shows 117. Non-standard tyres or wheels could mess this up though.
Hi there folks,
Thanks for your help with all the firmware troubles. Have successfully upgraded from 2680 to 4120 today.
Does anyone have a copy of V5 maps? I can't seem to find any working links.
Happy to throw some beers in for your troubles. I'm based in Windsor in Melbourne. I also have a Micro-CAN Interface if anyone needed to borrow it.
Thanks,
Josh
2010 Mk6 GTI / CW / 3dr / DSG / 18" Detroits / RNS-510 w/VIM! / RVC / Bi-Xenons / MDI / Euro Plates / 9W7 / VCDS Micro-Can / APR Stage 1
Look in the 'look here first' sticky thread in the audio section of the forums.
Thanks Ryan. Found the link. Appreciate your help.
