Page 18 of 112 FirstFirst ... 816171819202868 ... LastLast
Results 171 to 180 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #171
    Apr 2012
    NSW
    Quote Originally Posted by aussietig View Post
    FW and map are mutually exclusive!
    However logically (and just like your computer), you wouldn't update map (software) first, if you're going to update the firmware (Operating System).
    Now normally after you upgraded the OS on your computer, how do you reinstall all the software on it?
    I think you need the map disk, if you want to have any maps on your RNS510 after the firmware upgrade.
    Ok so maybe I wasn't completely clear.. I have seen the discussion about Australian maps V5 and the poi's.. I wasn't sure whether they were on a disk also.. I did see there were 5 .rar files to unpack.
    So I update the firmware, (which will allow me to have the DVD player viewed while in motion?) and afterward reinstall the maps from DVD which I will get from my VW dealer?
  2. #172
    Correct. The firmware disc does not contain the maps. The 4020 firmware image from this forum is not destructive though, so you may still have your current maps after the firmware upgrade.
    MY12 Polo GTI
    Factory Options:
    Candy White | 3dr | Comfort Pack | Bi-Xenons | Alarm | Jacky Cloth
    Customisations:
    RNS510 + SSD | Bluetooth | Watch this space!
  3. #173
    Apr 2010
    Depends if the current firmware has the same number of partitions and if they're the same size.
  4. #174
    Pacific Paradise QLD
    Despite reading this thread twice I am going to ask a question as I only found out the details of my unit today
    Control Module Part number 1TO 035 680 C
    Component or Version RNS-MID H50 2840
    It then says software Coding is 04000402040000A000
    It has no secret menu on it and I have been unable to get it to appear.
    It has vers 4.1 maps from last September in it Is there a newer vers like 5.1????? Since then
    How can I get secret menu and VIM to appear and do I actually need a firmware upgrade.
    Thanks in advance.
  5. #175
    Apr 2010
  6. #176
    I thought the software code would perhaps be the firmware or is it the map version
    Further down the diagnostic it has Advanced identification
    Serial number VWZ6Z7L5072026
    Revision AB001001
    Date 13 03 11
    Manufacturer number 0004
  7. #177
    Apr 2010
    The code is the coding (settings/options) that can be edited in VCDS I think.
    My C unit came with firmware 2760, and the firmware updates here added the secret menu so that you could find out what version you're on (by which stage you'd already know).
    See SW version on right and part number matches yours.
  8. #178
    Jul 2010
    Thanks in advance.
    On paper ... you have a C unit and the official stock FW version 2840!
    But it's as old as my grandma!
    If you can live with the slower performance or lag in displaying your position on the map, then I'd recommend FW 3970 with V5 map combo (from a fellow C unit owner).
    MY11 Tiguan 147TSI (SOLD)
  9. #179
    Oct 2009
    Cairns, Qld
    Ok guys I'm a bit of a gumby when it comes to this sort of stuff but can anyone (in very average person speak) please explain how I get to the stage of burning the ISO image. I have downloaded all the parts which come in ZIP file format and then tried to unzip each file but as far as I can see it only unzips Part 1 which creates a file in ISO format. Does this one file include all the other Parts and all I have to do is burn the one ISO image to disc or is there more to it?
    Please be gentle as I am an old man with limited ability in the modern world.
    cheers and thanks in advance
    Murray
  10. #180
    Apr 2012
    Gosford, NSW
    I'll try to make this easy The first thing you need to do is have all 5 parts in the one folder. Click and open part 1, this then opens and when it's finished opening, part 2 will auto start opening, then 3 then 4 then 5. All 5 parts will unzip into a single folder/file. (This is from memory and I'm afraid, I'm an old codger too, so I'm a bit rusty.) When all 5 parts have unzipped you can burn the ISO file/s. I hope this helps.
    MkVI GTD fitted with Bluetooth & MDI, CSG, DSG, Xenons, RNS510 with Dynaudio, ACC, Weathershields, Mudflaps, Sunroof, LED Tails, LED Indicators, LED Foglights, Interior LEDs, Tinted, RVC and Towbar - Gosford.
