Error Code 010303 usually means this:
A SWL error occured and now the maximum SWL Error Count has been reached. SWL is now blocked until a power cycle is initiated using the following
<SETUP> + <MIC> + <EJECT>"
More information required.
Which firmware are you loading to what unit running what firmware?
Also what software did you use to make the cd/dvd and what settings?
It more than likely just a media error.
Sent using electrickery
I have a C unit in my MY11 R, and I've upgraded to 3870 (beta) so far (upgrading to 4020 when I get around to it).
In the MY11.5 vehicles onwards, a mute button for the optical parking system (OPS) was introduced - this is a soft button on the RCD/RNS touch screen.
Does anyone know if the 39XX/40XX firmware and/or VCDS coding can add this feature for an MY11 or earlier system? Love my OPS/RVC but trying to back up when I have a sleeping child in the back is problematic as I don't want the beeping to wake them!
Thanks for any assistance!
MY11 Rising Blue 5dr DSG Golf R
Not sure what firmware revisions it is available in but I would assume all of them? - there is a mute button on the RNS510 screen when the OPS is enabled by selecting reverse or using the physical OPS button (where installed). Its in the bottom right corner I think from memory. Has a picture of a speaker or some such...
Thanks for your response - it is definitely not there on the 3870 I am running, but that is a beta version that was only released around the time the MY11.5 changes were announced (end of 2010) so it may not have incorporated the mute function.
I will try and find time over the weekend to upgrade and will post the results - I have been looking into this for a while, but searching for terms like RNS 510 OPS parking mute gets a lot of results that are not relevant to what I am after.
Bottom right icon.
Running 4020 fw I also have the physical P button however that turns the whole ops system on and off not just mute.
Yup - missing that button, have the P button but as you say it turns off OPS and RVC. Do you have C or D rev hardware? If you have C rev then I am optimistic that the upgrade will deliver for me.
Interesting. Let us know if fw upgrade does the trick otherwise ill look through vcds to see if there might be an option somewhere. Doesn't make sense to be a hardware limitation.
So it is not (just) firmware, now running 4020 with no mute option. Most likely VCDS coding will enable it, but I guess there is still the possibility it is hardware related somehow (VW DRM - feature only present if correct hardware detected?).
