Does anyone know if I can do a direct upgrade from SW/FW 1024 to one of these, or will I need to do a gradual first? Unit is a 1Z0035680A which I believe if upgraded would become a 3T0035680B afterwards.
when you say "Still copying to the HDD"...can you elaborate please? How do you know this? Have you tried to eject the disc, and there is a notice saying that this will interrupt/cancel the map loading process?
Have you tried to go for a drive while the map is loading (helps the GPS to set itself up and establish correct position).
Map loading (with good GPS reception) should take no more than 20 minutes. I wouldn't try uploading Personal POIs until you can establish that the map is loaded to the HDD.
Maybe your map data is bigger and will take longer to copy, assuming there is enough HDD space.
