Page 112 of 112 FirstFirst ... 1262102110111112
Results 1,111 to 1,116 of 1116
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #1111
    Mindarie, Perth (WA)
    Quote Originally Posted by Mattafro View Post
    is there a way to reload the firmware that it already has?
    you would need to downgrade to an older version first, then 'upgrade' to the desired version.
  2. #1112
    You can reload the same version. It's considered a 'downgrade' as it's not going to a higher version.
    Enable developer mode and then go into the menu and enable software downgrade.
  3. #1113
    well, I stand corrected. Cheers J (@kamold )
  4. #1114
    Pacific Paradise QLD
    Quote Originally Posted by FJ Steve View Post
    Cant do that with same version of maps Easy to get confused I have found LOL.
  5. #1115
    Apr 2020
    Wollongong-ish
    it worked, i found a video on youtube on how to install firmware, it had a link to firmware, burnt it at 10x speed, chucked the disc in, no ignition, just press button with everything off... it worked. i now have sound, was able to change language to english and didnt lose any maps. its perfect. so happy. thank you all for your help so far.
    this is the link i used. RNS_510_FW_5238_update_modified.rar - Google Drive
    version 5238. good luck to all that need the file!
  6. #1116
    good stuff
    Thanks for reporting back with your success
