Page 111 of 112 FirstFirst ... 1161101109110111112 LastLast
Results 1,101 to 1,110 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #1101
    Oct 2023
    Melbourne, Victoria
    Au iso images
    Shared Links to both disc iso files
    RNS510 OEM AUS firmware update 6276
    RNS_510_OEM_AU_FIRMWARE_VER_6276.iso - Google Drive
    Hawkedit: Removed copyrighted maps. If you can provide a link to an official source I'm more than happy for it to be shared.
  2. #1102
    Apr 2020
    Wollongong-ish
    Quote Originally Posted by cbr View Post
    wait, sorry, what is this?
    newer version?
    i got hw ver h09
    sw ver 5238 can i use this?
    i got no sound and language on display is stuck in german... thoughts on if this may help?
  3. #1103
    Pacific Paradise QLD
    Quote Originally Posted by Mattafro View Post
    newer version?
    i got hw ver h09
    5238 was what most of us used and it worked fine.
    Make sure 6276 isnt for Euro units as partitioning can be different as maps are a different size.
    Is so long ago cant quite remember what was what. Eurocarupgrades had the latest map for about $175
  4. #1104
    Apr 2020
    Wollongong-ish
    how.... do i find out if 6276 is for euro or here in oz? i mean.. without installing it...
    what gets me is.. my unit has the fancy reverse camera with lines etc. how does upgrading the firmware not effect any of this?
    i just want my sound back.. crying face emoji.
  5. #1105
    You have the rechesburg????? syndrome and if you look back quite a way in the threads you will see it was quite common for a while and the solution to fixing it is there also Need to go back about 7 years or so Page 87 first post tit and go for a drive for 30 mins to let it find where it is ONLY PUT 6276 if you have A LATE MODEL DAB model 5238 is enough
  6. #1106
    Apr 2020
    Wollongong-ish
    cant be the drive,
    i drove it to sydney and back (im in wollongong) thats about 2 hours there and back... its in german, wont change back...
    also, i have lost all sound in the unit..
    im happy to do a firmware update, would rater reload what i already have though to keep it the same,i tried to load the verion on page 1 but it tells me in trying to downgrade and it wont allow it.
    fyi, delivery part number 1t0035680L
    hw version h09
    sw version 5238
    map version 7920
    the error code i get is 010304
    it says target is loaded with 5670902 and inserted media is the same..
    wont let me re-load it.
    any way to force a reload? to try and get the english language pack and stereo sound to work?
    realy appreciate your help so far.
  7. #1107
    Apr 2020
    Wollongong-ish
    is there a way to reload the firmware that it already has?
  8. #1108
    Mindarie, Perth (WA)
    you would need to downgrade to an older version first, then 'upgrade' to the desired version.
  9. #1109
    You can reload the same version. It's considered a 'downgrade' as it's not going to a higher version.
    Enable developer mode and then go into the menu and enable software downgrade.
  10. #1110
    well, I stand corrected. Cheers J (@kamold )
