Page 90 of 112 FirstFirst ... 40808889909192100 ... LastLast
Results 891 to 900 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #891
    Pacific Paradise QLD
    Quote Originally Posted by FJ Steve View Post
    Hillbilly is pointing out the technical deficiency of your request. Asking for links to download the maps is taboo.
    However, if you were to ask if someone could assist by re-loading their disc onto your unit after you have done the FW update, may find a different response.
    Ask for assistance that does not involve an illegal process.
    Ha ha Thats still technically illegal but maybe someone will oblige LOL
    New V9 maps are $199 from GKU You might get a V8 which most of us have for about $55
  2. #892
    Not anymore......$595 and they're out of stock.
  3. #893
    Quote Originally Posted by willsy01 View Post
    A stealer might have some old stock of V8
    JKU advertising it for $99
  4. #894
    Oct 2012
    Hi Everyone,
    Just wondering if anyone definitively knows which firmware I have to downgrade to to avoid the battery drain? I gave 5xxx, 4xxx (with swapped tables) and now 2760 on my H04 A revision RNS and haven't had much luck (killed the battery twice on the 4 and 5 firmware versions). I have yet to test the 2760 firmware as I couldn't afford to risk it with work (have been pulling the fuse out) so was wondering if this should fix it? Is there any way to potentially tell if its not shutting down properly?
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
  5. #895
    Read through the thread Im pretty sure its nothing to do with firmware Its a module in the car needs upgrading. Kamold will know but its been discussed a lot so maybe a search on "Battery drain" will help
  6. #896
    Mindarie, Perth (WA)
    update from CANBUS 1.6 to CANBUS 2 is required to avoid battery drain
  7. #897
    Canbus gateway upgrade is the most complete solution.
    However in some cars (eg 2007 Golf where its up behind the upper relay carrier behind the dash) it's a pain to get to.
    This firmware has some tables swapped so should prevent the RNS staying awake when it should be going to sleep after 30mins:
    http://www.rnsfirmware.com/downloads...CD_4020_M3.iso
  8. #898
    Mar 2009
    Melb
    Old site but still useful
    my-gti.com |
    Tig 162 R-Line; Audi TT
  9. #899
    Oct 2012
    Thanks Kamold, you have done much more than you get credit for on this topic!
    unfortunately i have tried this firmware with the tables swapped (guessing its the same as the one off the my-gti website?).
    Seems like 2760 might be causing battery drain as well. I have 960 in there before and that didnt cause it, so perhaps I will have to go all the way back to that
  10. #900
    I would replace the gateway so that you can use current firmware.
    But that's me.
    You can get a gateway from online sellers that will have it already correctly coded for you if you don't want to use VCDS or OBDEleven etc to configure it.
