Not if it was factory installed. They are available aftermarket from Europe but are more expensive than regular units
Sent from my HTC One M8 using Tapatalk
Absolutely certain. I took photos to make sure when I was checking
Thanks for the info
I'm not that brave tbh. I am brave enough to wait for Kamold.. Speak of the devil.
Shall do. Would this guy support DAB+?
Thanks everyone for the replies.![]()
Just a quick follow up guys.
The dealership I bought my car from is telling me that I already have the latest maps and that everything is up to date.
They also told me they updated the headunit software, but they've indicated they flashed the version I already had.
This obviously flies in the face of what you guys have said. I just wanted to check with you all as I don't really trust my dealership :/
Thanks in advance for any help![]()
Hold the setup button in until a screen comes up with "Version information" on it Press that
Take a picture of it and post it on here.
Then we can tell you what you have.
The latest firmware on here is modified to give different partitions for more music so wont be added by any dealer.
If you have an SSD based unit with 6000 series firmware on it, do not downgrade to 5238.
I will eventually get around to modifying and uploading an image for these units.
- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
- 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
There is on gpsunderground but I haven't modified it yet with custom partition ratios etc
Hi all, first of all - many thanks for the detailed data on updating firmware for the RNS 510. Went through about 8 CDs, and DVD's before it finally recognised a properly burned iso. After the update I've noticed that I'm now missing the Nav and Audio pages on my MFA however. A quick google search suggests I need to recode via VCDS in order to get the data back.
Should I take it to the dealer to get this done??
