Ok, so I downloaded some iso burner software and tried again with another (my third!) CD-R and then put it into the RNS510.
Viola, it works! So obviously there was a problem with my burn. Now time to turn my attention to the RVC...
One further question. When I checked the set-up information it said that my map version HDD was 8035? Does that equate to V7, or something else?
So I just bought a Jetta with the RNS 510, and am trying to work out what the go with my head unit is.
At the risk of sounding stupid; I've done some research through the forums and looked at all the different part numbers. As best I can tell they all start #t and end with the country code (680).
Mine is a tad different:
Delivery Part Number: 1K8035680
HW Version: H05
SW Version: 6276
Map Coverage: Australia + New Zealand
Map Supplied: Sensis
Map Version HDD: 7920
Am I missing something here or doing something wrong?
Apologies in advance if I've missed a post here.
EDIT:: I'm aware I took this info from the radio "secret menu", but I couldn't get the head unit to go the the second secret menu. Just in case that's relevant.
7920 is V6 latest is V8 Are you sure about the SW no as 5238 is latest most are running
However if its a brand new car it could be right and have the latest DAB+ board in it
Doubtless Kamold will come on and get it right for me
I believe a tweak to the firmware CD enabled the second secret menu. You could pry the plastic fascia off and remove the T20 screws and pull the head unit out to reveal all he various ID numbers on the sticker. Or wait for kamold
That's a brand new ssd based unit. You can enable secret menu with vcds.
Sent from my HTC One_M8 using Tapatalk
If the car is new go back to the dealer and ask them to load the V8 maps into it FREE
