Page 76 of 112 FirstFirst ... 2666747576777886 ... LastLast
Results 751 to 760 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #751
    Dec 2009
    Kew, VIC
    Quote Originally Posted by prn31 View Post
    So it seems somehow, embarrassingly, that I burned the 4020 firmware to both CDs! Doh! I have now burned the V7 maps to a CD-R. The RNS510 tells me to insert a DVD and comes up with an error when I load my CD-R. So should I burn the V7 to a blank DVD? I'll give that ago and see how I go....
    I had a B series RNS510 — it didn't care whether it had a CD or DVD, so maybe the burn is faulty.
  2. #752
    Pacific Paradise QLD
    Quote Originally Posted by Idle View Post
    The V7 map i have is 697MB so will have trouble fitting on a CD Also you could be correct Write with IMG burn as slow as possible
  3. #753
    Mindarie, Perth (WA)
    ^^^this.
    Always check the .iso file size before committing to the burn process.
  4. #754
    May 2015
    Ok, so I downloaded some iso burner software and tried again with another (my third!) CD-R and then put it into the RNS510.
    Viola, it works! So obviously there was a problem with my burn. Now time to turn my attention to the RVC...
    One further question. When I checked the set-up information it said that my map version HDD was 8035? Does that equate to V7, or something else?
  5. #755
    Yes. 8035=AU/NZ v7
  6. #756
    Jul 2015
    Shailer Park, Australia
    So I just bought a Jetta with the RNS 510, and am trying to work out what the go with my head unit is.
    At the risk of sounding stupid; I've done some research through the forums and looked at all the different part numbers. As best I can tell they all start #t and end with the country code (680).
    Mine is a tad different:
    Delivery Part Number: 1K8035680
    HW Version: H05
    SW Version: 6276
    Map Coverage: Australia + New Zealand
    Map Supplied: Sensis
    Map Version HDD: 7920
    Am I missing something here or doing something wrong?
    Apologies in advance if I've missed a post here.
    EDIT:: I'm aware I took this info from the radio "secret menu", but I couldn't get the head unit to go the the second secret menu. Just in case that's relevant.
  7. #757
    7920 is V6 latest is V8 Are you sure about the SW no as 5238 is latest most are running
    However if its a brand new car it could be right and have the latest DAB+ board in it
    Doubtless Kamold will come on and get it right for me
  8. #758
    Apr 2010
    I believe a tweak to the firmware CD enabled the second secret menu. You could pry the plastic fascia off and remove the T20 screws and pull the head unit out to reveal all he various ID numbers on the sticker. Or wait for kamold
  9. #759
    That's a brand new ssd based unit. You can enable secret menu with vcds.
    Sent from my HTC One_M8 using Tapatalk
  10. #760
    If the car is new go back to the dealer and ask them to load the V8 maps into it FREE
