Page 72 of 112 FirstFirst ... 2262707172737482 ... LastLast
Results 711 to 720 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #711
    Feb 2015
    S.E burbs Melbourne
    I can now interrogate the unit by holding the setup button and have discovered my h/w version is 0006. So I may try to upgrade to 52xx firmware and see if I have more luck. Although the minimum burn speed my laptop will do is 10x which I believe may cause issues...hmmmm dilemma's.
    Nevertheless thanks to all the tireless efforts of those that post the information and provide advice. Muchly appreciated!
  2. #712
    Mar 2011
    Gold Coast QLD
    Quote Originally Posted by Nos View Post
    -I thought the H/W version relevant to the latest version firmware you can run ends in a letter... but I think radio HW 0006 is usually in the later LED units ... C+ so should be OK
    Same here, minimum 10x write speed, common in the newer CD burners/Cd media. I wouldn't worry about it, I never had a problem with it using IMGburn.
    - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
    - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
  3. #713
    Feb 2015
    S.E burbs Melbourne
    Thanks YL, I am in the process of loading it onto dvd-rw (due to size) now. Fingers crossed it goes smoother than the 4120 upgrade.
  4. #714
    Mindarie, Perth (WA)
    cdburnerxp allows burn speed down to x1. use "Track-at-once" burning method.
  5. #715
    Quote Originally Posted by FJ Steve View Post
    The software lets you select that, however the burner itself sets the minimum speed. You will request 1x and receive the lowest available, usually 16x these days...
  6. #716
    cheers.
  7. #717
    Feb 2015
    S.E burbs Melbourne
    5238 loaded and all went smoothly, thanks all for the tips.
  8. #718
  9. #719
    Apr 2009
    Northern Tasmania
    Is this firmware appropriate (ok for Australians)? version 6276
    Volkswagen RNS 510 Firmware Upgrade to version 6276 | my-gti.com
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
  10. #720
    Pacific Paradise QLD
    Quote Originally Posted by wfdTamar View Post
    Unless you have a very new unit with DAB+ I wouldnt use it as you could brick the unit
    The 5238 on here is probably the latest you should use What version is your unit
    4120 is Ok and there is no reason to go higher as there are no obvious improvements in 5238
