Page 62 of 112 FirstFirst ... 1252606162636472 ... LastLast
Results 611 to 620 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #611
    Sep 2014
    Greenslopes, QLD
    please confirm. You have a 1T0 035 680 B HW004 with radio board 0003, and its successfully running 5238? So no dab isn't a show stopper?
    .:R36 MY10.5::Wagon::Biscay Blue::Adaptive Dampers::Sunroof::Wheels:.
  2. #612
    Its not the no DAB that is the issue.
    Older radio boards use a different flash chip which is more susceptible to premature death by flashing.
    Can be done at your own risk
  3. #613
    Sep 2014
    Capalaba, QLD
    Yes I can confirm that I have a 1T0 035 680 B HW004 with radio board 0003, and its successfully running 5238. It loaded fine and everything is working including RDS.
  4. #614
    Dec 2010
    Sydenham Vic
    Quote Originally Posted by Sim T5 View Post
    X2. I have now used this SSD in two RNS510 conversions. Works very well and excellent value for money.
    Stuart...
  5. #615
    Jan 2015
    Brisbane, Queensland
    I have a 2011 B7 Passat.
    The RNS510 doesn't show in the secret menu its firmware version. Only shows the AM/FM radio manager settings. I don't have a cable to interrogate the computer so I'm guessing the only way I can see what firmware version the unit is sitting on is to open the thing up and look at the sticker.
    Question though is, how? How do I get about getting at the unit? Is there a guide showing me potentially what tools I'll need which will let me get the covering surround off without damaging the clips so I can unscrew and look at the sticker?
  6. #616
    Pacific Paradise QLD
    Quote Originally Posted by dero View Post
    Download 4020 and try it My mid 2010 had 2860 or similar It now has 4120.
    You need a set of these to remove panels VW Audi BMW Nissan Ford Honda Interior Trim Clip Removal PRY Tool KIT Radio Dash | eBay
  7. #617
    Jan 2015
    Cheers - thank you very much - I'll get a set of those tools.
    Is there some sort of guide or an image where I can reference to see where the clips sit and how it is to be used?
  8. #618
    Don't really need trim tools to get the head unit surround off. Just pry off with your fingers under the bottom edge.
    Then you have 4 T20 Torx screws.
    But I wouldn't bother with any of that.
    Your unit if factory fitted will be running 2760.
    Just load 4120.
  9. #619
    Sep 2014
    Greenslopes, QLD
    're Zheino SSD...
    Any idea what controller it uses? I noted it uses MLC NAND ... So longevity might be an issue depending on wear levelling and controller managment of reserve cells/space. I couldn't find any reviews. I had considered using an IDE SD card adaptor with a extreme pro or similar card using SLC flash... But it's slightly more expensive option and untested in this application afaik.
  10. #620
    Unless you're deleting and reloading music every day I don't think cell endurance is really going to be an issue.
    If the drive dies, just replace it...its not like it costs much.
    Otherwise stick to the overpriced Hitachi spinning disk.
